TDC guarantee ? - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 07-04-2014, 01:57 PM Thread Starter
jamieandthemagi's Avatar
TDC guarantee ?
Need to take the head off the junior tomorrow as there's no compression on 4.
There's no marking on my front pulley. There's a triangle marker behind the pulley, that no way lines up with the top, so lining anything up would be very hard.
My cam lobes are both facing out on piston 1. The cam markers are both lined up. The piston is at the top of its stroke (screwdriver in hole test). The dizzy arm is at piston 1.
Safe to remove head?????
Just cautious without true TDC mark on pulley.
1989 Alfa 75 3.0V6 & 1971 Alfa Giulia GT1300 Junior
jamieandthemagi is offline
post #2 of 4 (permalink) Old 07-04-2014, 03:50 PM
Should be good. I would make a mark on the pulley that lines up with the pointer.
gprocket is offline
post #3 of 4 (permalink) Old 07-04-2014, 04:03 PM
make sure the distributor is pointing at piston 1, make a mark on pulley for next time
pedrov is offline
post #4 of 4 (permalink) Old 07-04-2014, 06:06 PM
Andrew's Avatar
P is TDC, the pointer should be on the waterpump, but they do get left off. You can get close to TDC with a vertical pointer in the #1 cylinder, turn til it rises, stops, starts to file. There's a short arc of almost no movement.
Andrew
Andrew is offline
