Gas gauge or sender problem ? - Alfa Romeo Bulletin Board & Forums
post #1 of 11 (permalink) Old 04-20-2014, 09:15 AM Thread Starter
brad fischer's Avatar
First drive of the year all is well except my gas gauge reads very near 0 and the red lite is on in the gauge. Before I look into any thing I will guess the float has a hole and sunk. Anyone else want to offer a guess???
brad fischer is online now
post #2 of 11 (permalink) Old 04-20-2014, 09:34 AM
74 GTV's Avatar
Hi Brad,
The sending unit is easy to get to and test. You may wish to start there and first check if the connections are sound before removing the unit from the top of the fuel tank for troubleshooting. At least you know your low fuel level light works. I did have to replace my sending unit some years ago.
I'm sure you'll have many opinions on this one... good luck !
-Doug
74 GTV is offline
post #3 of 11 (permalink) Old 04-20-2014, 10:56 AM
Gubi's Avatar
The gauge part and the light are actually two different circuits on the sender. Basically the only way I can think of for them to actuate at the same time is for the float arm to be physically down. So a float problem seems likely.
That or you forgot to fill up the tank last fall...
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is offline
post #4 of 11 (permalink) Old 04-20-2014, 11:02 AM
Alfajay's Avatar
If the connections at the sender weren't good, the "low fuel" light wouldn't be on. No, think the problem is probably mechanical and not electrical; e.g., the float has indeed sunk.
Alfajay is offline
post #5 of 11 (permalink) Old 04-21-2014, 05:05 AM Thread Starter
My 1st guess was that I forgot to fill the tank last fall, first trip was to get a fill up, took 1 litre of gas. Checked my fuel mileage log book, I did indeed fill it last fall. 2nd guess after that was that the float sunk.
Can a Veggia and Jaeger sender be identified when installed in a tank. I have a spare tank with a sender I think, I will have to dig it out of the garage attic, will be my luck to be a Jaeger, when my gauges are Veglia.
post #6 of 11 (permalink) Old 04-21-2014, 01:34 PM Thread Starter
Interesting, today when I drove it, I started to notice the gauge slowly creeping up from 0, the red lite went out. It was at 1/4 half way through my 10 mile trip and at 1/2 when I pulled in the garage. Float regaining buoyancy? Don't think so? Maybe the resistance of the wiper contact was too much and it cleaned up with some motion? Last year I recall that a fill up would only produce 7/8 - 3/4 reading on the gas gauge.?
post #7 of 11 (permalink) Old 04-22-2014, 08:30 AM Thread Starter
Got my spare tank out, it has a Veglia sender. Took the sender out, snapped 1 small machine screw of the 6. Want to take the rectangular plastic cover off the sender for inspection, don't want to break it.
My gauge today reads 5/8 of a tank today, odd? The resistance to ground of the variable resistor in the sender is about 55 - 60 Ohms. It looks like the Veglia sender is designed to be about 10 Ohms at E and about 100 Ohms at F, Those #s are from my spare gauge. So my previous theory about some contacts cleaning themselves after some motion looks wrong.
post #8 of 11 (permalink) Old 04-22-2014, 09:43 AM
I have a similar problem but when I tap on the gauge it often will go up as does my oil pressure gauge. Maybe these two gauges have a common ground?
Todd
'59 Sprint '71 GTV
toddfiebig is offline
post #9 of 11 (permalink) Old 05-16-2014, 01:13 PM Thread Starter
Wired up and grounded my spare sender in the trunk to test, works perfect. On my last drive the OE sender in the tank caused the gauge to read 3/4 tank. It is getting better each time I drive it. Weird, self fixing sender problem? Will have to wait a while till I drive enough miles to get the tank to under 1/4. How critical is the gasket between sender and tank? Can it be reused?
post #10 of 11 (permalink) Old 05-16-2014, 02:22 PM
Reuse if you are lucky but whatever you do, do NOT use silicone
Chuck
f4driver is online now
post #11 of 11 (permalink) Old 07-04-2014, 02:20 PM Thread Starter
Tank was near E so I had the time and inclination to swap out my sender. Found the original in the tank with the screen worn out and the float partially full of gas. Problem solved now the gauge reads a little higher.
