Carb mount differences, single, double, long, short, etc. - Page 5 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #61 of 65 (permalink) Old 01-25-2017, 11:53 AM
GTA R's Avatar
I've always just used the paper gaskets dry, making sure that both the face of the inlet, and the carb mounting faces are nice and clean and flat.
Some people use a smear of grease, some use sealant. no hard & fast rule as long as they seal ok.
Steve
GTA R
1963 Giulia Ti Super Rep
GTA R is offline
post #62 of 65 (permalink) Old 01-25-2017, 12:31 PM
Gary Williams's Avatar
I've used a very light coating of grease on the gaskets for the past several decades. It was a tip from a WWII warbird mechanic that has served me well for decades. You want your Alfa's carbs to be free of air leaks when you head into combat!
Gary Williams
Washington State
'67 GTV
Gary Williams is offline
post #63 of 65 (permalink) Old 02-24-2017, 09:26 PM
Yachtman's Avatar
Swallow. Perfect timing for resurrecting this post. I've been reading everything I can and I guess too many answers is bound to confuse (??) anyone, let alone me.
**I'd like to hear what SB Pilot used for gasket sealant on his manifold, both sides.
**And also what nuts/washers for the inside of the manifold holding the carb mounts?? (I've had a lot of bb help with this, but since this is the exact set up I'm about to change to, his experience would be beneficial. Especially if they held tight!!)
I know this post is an old one, but should provide good experience from what has worked for SB.
Thanks again,
[B][I][U]Current[/U][/I][/B]
1984 Spider Veloce Deluxe
1969 GT 1300 JR
1969 1750 Spica Spider Veloce
1963 MGB
1952 MG TD
Others??!!!😃😃
Yachtman is offline
post #64 of 65 (permalink) Old 02-25-2017, 05:51 AM
brad fischer's Avatar
Originally Posted by Gary Williams View Post
I've used a very light coating of grease on the gaskets for the past several decades. It was a tip was a WWII warbird mechanic that has served me well for decades. You want your Alfa's carbs to be free of air leaks when you head into combat!
I use grease as well, a tip from my father's generation.
brad fischer is offline
post #65 of 65 (permalink) Old 02-25-2017, 10:07 AM
INRE grease for carb gaskets:
Combat air mechanics used grease in part because they'd take the carbs off a LOT (crappy fuel). Modern A&P guidelines have an aircraft-fuel rated gasket sealer for this application.
Robert
60sRacer is offline
