1300/1600 brake upgrade question. - Page 2 - Alfa Romeo Bulletin Board & Forums
post #16 of 27 (permalink) Old 04-05-2018, 02:04 AM
quadrifolio's Avatar
I did it in my conversion, no problems 7 years later, those bolts are special and I prefer to cut them to size and reuse them than using an inappropiated bolt for the aplication, caliper gets hot when braking so I prefered to reuse them
quadrifolio is offline
post #17 of 27 (permalink) Old 04-05-2018, 02:16 AM
AlessandroM's Avatar
Arent they just regular zinc coated Class 10.9 bolts? I don't think there is something such as special steel that mimics the characteristics of alu (with heat) and is hard at the same time.
Learning, learning..
AlessandroM is offline
post #18 of 27 (permalink) Old 04-08-2018, 12:51 PM
jema's Avatar
Cut them to size
I would be afraid cutting those and thus killing the zinc protection - calling for seizing doesnt it? We had a hard time getting the original bolts out because they were heavily corroded.
Just for this corrosion issue, I bought titanim screws with the right length. Aluminium and titanium does not have galvanized corrosions.
Also, it weighs less 🙂
//Mattias
jema is offline
post #19 of 27 (permalink) Old 04-09-2018, 07:55 AM
brad fischer's Avatar
Was it not a common upgrade for 1300/1600 GT/GTV/GT Jr to install bigger brakes from 1750/2000 GTVs? If so what is actually bigger? Front caliper pistons, pads, rotors, and or rear caliper pistons, pads or rotors ????
brad fischer is offline
post #20 of 27 (permalink) Old 04-09-2018, 08:03 AM
Andrew's Avatar
My two cents. I vintage-raced a 71 Super with a mid-level-prep race 1600; I never felt the need to upgrade from stock brakes. I never used them up, but maybe I wasn't driving hard enough!
When I got the car it had Milano front calipers on stock disks, wasn't noticeably worse going back to stock as required by CSRG.
Andrew
Andrew is online now
post #21 of 27 (permalink) Old 04-09-2018, 10:54 AM
kengta's Avatar
Brad, while I am no expert on this subject and few other subjects for that matter here is my IMHO and all is subject to correction by real experts.
I think every thing up to the 1969 1750 GTV's have small front Ate brake calipers Except the Dunloped cars. This meant an upright with a 3" caliper mounting bolt spacing for the smaller caliper. The 1750's (although I thought I had come across a 69 GTV with small ATEs) and 2 ltrs had bigger front calipers and the upright had 3.5" mounting bolt spacing. Bigger caliper bigger pads. Not sure on the rotors size. The Interchange book shows the same pistons for both large and small ATEs. I think the rears were the same on all but the interchange book says different. And BTW there were other variations in the uprights with respect to the height.
As the interchange book is a consolidation there may be variation from the original parts books I suppose.
The lesser models after 1969, that is the 1300's and 1600's, continued with the Small ATEs. My 1975 build 1600 GTj has them and Andrew noted them on his 1971 Super.
So FWIW
Ken
kengta is offline
post #22 of 27 (permalink) Old 04-09-2018, 10:57 AM
Andrew's Avatar
Yes. The Late Juniors and Supers have "small" ATEs but are not identical to earlier pre-1750 1600 ATEs. I forget the specific issue, I think the disks/hubs were different front earlier, even though the calipers are the same?
Andrew
post #23 of 27 (permalink) Old 04-09-2018, 05:35 PM
Thanks Ken. That is how I thought is was with brakes. I got confused when Larry with the 66 GTV was telling me about the problems he was having getting pistons for his rear ATE brakes. Seems to me that the piston dia was hard to get?
post #24 of 27 (permalink) Old 04-09-2018, 09:08 PM
In mid to late 1967 the front Dunlop's were changed to ATE's.
But there is a catch.
They kept the front Dunlop upright and just modified the adaptor,
so now you have a Dunlop upright plus a Dunlop adaptor for a Dunlop front caliper or
A Dunlop upright with an ATE adapter for an ATE caliper.
You can see the pictures of the different adapters in the parts book.
It could be the 1966 car was later upgraded to a 67 ATE (adapter and caliper only), as opposed to using the GTJ 1300 ATE system which was the 1968 upgrade where they incorporated the upright with out an adapter.
I am not sure about rear ATE's, I thought all the 1967 GT Veloces remained with rear Dunlops whilst with Dunlop or ATE front calipers.
Steve105 is offline
post #25 of 27 (permalink) Old 04-11-2018, 06:25 PM
There's a variant of the rear ATE caliper that is a smaller piston size (32mm?) that appears to have been used with ATE front brakes, but without the proportioning valve that the later cars got - this may have been part of the 1967 changeover period...
1966 Giulia Sprint GT Veloce - pretty much finished!
Bunch of bikes too.
la_strega_nera is offline
post #26 of 27 (permalink) Old 04-13-2018, 05:34 AM
JonasBerg's Avatar
Titanium sounds great but I'm afraid that would cost me as much as I paid for the callipers initially :-D Maybe as an upgrade once everything works as expected!
Does anyone know the part number for the Milano Brembo Brakes Refurbish set from Ate (which contains the seals etc.)?
JonasBerg is offline
post #27 of 27 (permalink) Old 04-13-2018, 06:01 AM
Subtle's Avatar
The "Brembos" are some 6 lbs lighter than the "bigger" brakes from the 2 L.
Then going from steel wheels to Alloy (TZ style) drops 3 lbs.
Bob,
Subtle is offline
