gta door handle conversion - Page 2 - Alfa Romeo Bulletin Board & Forums
 3Likes
post #16 of 24 (permalink) Old 04-27-2018, 10:53 PM
shane1750's Avatar
Hi
I have just fitted GTA style buttons .
Should the flat section be at the side (90 degrees )
or the bottom (180) ?
Gone: 1970 GTV 1750 S2, 1990 164, 1991 75TS, 2000 2.0 GTV 1x 1965 Giulia Sprint GT
Current: 2006 166 V6, 1 x 1965 Giulia Sprint GT
shane1750 is offline
post #17 of 24 (permalink) Old 04-27-2018, 11:42 PM
I have mine on the bottom...
I don’t have a reference, but I spent reasonable effort at the time checking.
They also had a tab on that needed to be cut as well as the hole.
samking is offline
post #18 of 24 (permalink) Old 04-28-2018, 06:27 AM
Trich's Avatar
Yup, on the bottom
My "rejuvenation" blog: http://65tomfoolery.wordpress.com
'65 Alfa Giulia Sprint GT, a long way to go still….
Trich is offline
post #19 of 24 (permalink) Old 04-28-2018, 08:23 AM
iachella's Avatar
Has anyone cut a scallop in the body behind the door instead of installing the grab handle? That's more body work, but would be great to grab the back of the door while pushing the button by sliding your fingers into a recess cut out of the body.
davbert likes this.
Stefano
Concord, CA
iachella [at] gmail [dot] com
iachella is online now
post #20 of 24 (permalink) Old 04-30-2018, 01:53 PM
Trich's Avatar
I'm sure you "could", it would just take a bit of work and planning. As you may know Sprint Speciale's are like that. One area they differ is SS's don't have the outer door gasket on the outer edge like GT's do, you'd likely need to eliminate that or cut it into two sections.
Trich is offline
post #21 of 24 (permalink) Old 04-30-2018, 01:56 PM
kinda of like the prototype Montreal style? :-) i like that too, sooo bertone
davbert is offline
post #22 of 24 (permalink) Old 09-02-2018, 05:00 AM
jema's Avatar
Hello
Well it seems as if the template linked in this thread is gone. Could anyone upload it again? Thanks
Ps. Also if anyone got a template for the rear view mirrors (on the doors)...
Signor Slowly likes this.
//Mattias
jema is offline
post #23 of 24 (permalink) Old 09-03-2018, 03:13 AM
shane1750's Avatar
Is this what you are after ?
GTA DOOR LOCK HANDLE TEMPLATE.pdf
post #24 of 24 (permalink) Old 09-03-2018, 03:52 AM
jema's Avatar
perfect, thanks!
//Mattias
jema is offline
Tags
door handle, gta, gtv
