Wiring diagram for 1960 giulietta spider 101 - Alfa Romeo Bulletin Board & Forums
post #1 of 9 (permalink) Old 08-21-2019, 06:08 PM Thread Starter
Hoping someone can email me the wiring diagram for my 1960 giulietta spider 101.
Thanks I couldn’t put my email in but can pm it to you.
Sean
searya is offline
post #2 of 9 (permalink) Old 08-22-2019, 07:22 AM
Group,
I have created a diagram for installing a fusible link and starter switch relay for the giulietta. As you may know, the ignition switch, light switch, and the two relays on the giulietta are on a un-fused circuit. The fusible link will protect this circuit. Also the relay will take the load off the starter circuit of the ignition switch. If you have an original switch, like I do, this relay is a must. Contact me off forum and I will send this diagram.
Reed
RWCearley is offline
post #3 of 9 (permalink) Old 08-22-2019, 05:10 PM Thread Starter
Thanks just pm'd you about the fuse diagram.
Also, if someone has the full wiring diagram I am still needing it. My email is [email protected]
Sean
1960 Giulietta Spider 101
searya is offline
post #4 of 9 (permalink) Old 08-22-2019, 07:02 PM
Barn101's Avatar
Sean
It's in the back of every shop manual, original, copy, or online PDF. See links above on this '55-'64 forum.
Barn101 is offline
post #5 of 9 (permalink) Old 08-22-2019, 07:44 PM
Group,
I also install a ground wire from the steering box to the engine. Helps with the starter relay. Can never have too many grounds.
Reed
post #6 of 9 (permalink) Old 08-22-2019, 07:53 PM
Centerline sells an 11x17 wiring diagram for not a lot of money: https://centerlinealfa.com/catalog/w...ram-101-spider
Much easier to read than the one in the owners manual.
6alfas is offline
post #7 of 9 (permalink) Old 08-23-2019, 01:11 PM Thread Starter
I will grab one of those as I tried but couldn't read the owners manual one very well
I also, posted in the electrical forum for this but if anyone has one of papjam's diagrams for my car I would love to have a copy of that as well
[email protected]
searya is offline
post #8 of 9 (permalink) Old 08-25-2019, 04:20 AM
Hi searya,
You could go to a copy centre with the owners manual and let them make some large copies of the wiring diagram and put it against a wall, it helped me several times not to get dizzy when following the small lines, you even can add important notes on each wiring line if needed .
Thierry
alfasprinty is offline
post #9 of 9 (permalink) Old 08-28-2019, 12:00 PM
facelvega's Avatar
Hello,
I attach a diagram in color for the 101.23 but the difference to the Giulietta is pretty small.
Alfred from Germany
best regards Alfred (Germany)
Giulia spider (101) 1964
facelvega is offline
