matching number - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Gordon Raymond
post #1 of 9 (permalink) Old 08-21-2019, 10:39 AM Thread Starter
facelvega's Avatar
matching number
Hello
I have a two question
1. regarding matching numbers:
My cylinder head number and engine number are different.
Is it mandatory for matching number that both numbers are identical?
My chassis nr. AR 377958, production 10/1963
engine nr. AR 00112*12729
nummer hammered in in the cylinder head: 18328
2. what is the tolerance in diameter of a valve rod between the upper and lower part.
is a difference of 7/100 mm ( 0,07 mm) acceptable ?
Alfred
best regards Alfred (Germany)
Giulia spider (101) 1964
facelvega is offline
post #2 of 9 (permalink) Old 08-21-2019, 12:51 PM
101/105guy's Avatar
Oh, we HAVE to have pictures of this!!
'64 Guilia Spider
'67 GTV
'68 Giulia Super
101/105guy is offline
post #3 of 9 (permalink) Old 08-21-2019, 10:22 PM Thread Starter
facelvega's Avatar
matching numbers
Hello, thanks for your reply.
I attach the picture of the cylinder head.
Alfred
post #4 of 9 (permalink) Old 08-22-2019, 06:58 AM
101/105guy's Avatar
No, no. The valve rod....
'64 Guilia Spider
'67 GTV
'68 Giulia Super
post #5 of 9 (permalink) Old 08-22-2019, 08:39 AM
Gordon Raymond's Avatar
The number pictured is an inspectors mark and has nothing to do with correct fitment of head to block. It indicates a series of gauging and machining processes were completed.
Gordon Raymond
Now:
Gordon Raymond is offline
post #6 of 9 (permalink) Old 08-22-2019, 09:45 AM
Andrew's Avatar
Heads don't have serial numbers. Some have part numbers cast in the front and as Gordon says, there can be manufacturing marks. But there aren't any numbered heads.
Andrew
Andrew is online now
post #7 of 9 (permalink) Old 08-22-2019, 09:47 AM Thread Starter
facelvega's Avatar
valves
@101/105guy
hello,
attached I send you the pictures from the valve.
Thanks Alfred
post #8 of 9 (permalink) Old 08-22-2019, 04:48 PM
Originally Posted by facelvega View Post
Hello
Alfred
I always thought matching numbers meant that their was a number on the chassis that also matched the engine. Is that true? My 1960 Giulietta Spider has a replacement 1.3L but came with the original engine and head. I am planning to rebuild it and put it back in at some point but if I am wrong on what matching is I am just going to start telling everyone it is matching numbers and skip the rebuild
searya is offline
post #9 of 9 (permalink) Old 08-22-2019, 05:43 PM
No. it is not true with Alfa's. Engine numbers do not match chassis numbers, and body panel assembly numbers do not match chassis or engine numbers. Same with transmissions and rear axle numbers. Most of these are either assembly numbers or variant numbers for specific applications.
Engine numbers do have a chronological build period, and prefix numbers may indicate model application.
This is a condensed version answer.
Barn101 likes this.
Gordon Raymond
Now:
