Correct position of rear soft top bar - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By divotandtralee
  • 1 Post By giuliettaspyder
post #1 of 11 (permalink) Old 05-31-2019, 12:36 PM Thread Starter
mudshark's Avatar
hello, a question..
I have started to get the curved bar, that holds the back of the soft top glued into it, where it goes on the deck.
Now I am not sure if the bottom of this V-shaped part should be pushed all the way in or it should stay just a bit out (there is enough cloth to attach it to)
If it stays out a bit, it would seem that the "cord" that is in the back would be behind the bar and almost flat on the deck, if I stick it all the way in, I would think it gets pushed between the bar and the deck. IMHO it should be the 1st option.
On the drawing, the one on top ....
Glad to hear your advice!
mudshark is offline
post #2 of 11 (permalink) Old 06-03-2019, 03:31 AM
divotandtralee's Avatar
I think the top photo is more appropriate.. the goal is to allow the edge of the canvas top to sit butted to the car's surface. I think if you go the other way it might be lifted a bit and look a little odd.
That metal bow was not really glued in place but rather "floated" inside the flap and hand sewn in place as I recall ...but don't take my word for it.
Barn101 likes this.
divotandtralee is offline
post #3 of 11 (permalink) Old 06-03-2019, 06:49 AM
giuliettaspyder's Avatar
I fitted my mew top from Elvezio about six months ago, and also did a lot of head scratching ..
In the end I butted the rear corner of the bow against the last line of stitching, so it looked a bit more like your lower photo.
That way when fitted, the "cushion" gets pressed down below the bow (it is quite soft and compresses easily) and the little flap of canvas that extends rearwards from the line of stitching lies flat against the body. Also worth noting in my case: if I had fitted it like your upper photo, the whole top would have been 5-10 mm further aft and then the 'side flaps' would have been too far aft to fit with the frontmost turnbuckle.
I know this explanation sounds a bit like greek ... so I have modified your lower diagram to hopefully explain better! The second photo is trying to show the final fit against the rear scuttle.
I do not know if this is the 'correct' way, but it worked for me and I am happy with the look and fit I achieved.
Mike
Sunny South Africa
Barn101 likes this.
giuliettaspyder is offline
post #4 of 11 (permalink) Old 06-03-2019, 06:55 AM
That way when fitted, the "cushion" gets pressed down below the bow (it is quite soft and compresses easily) and the little flap of canvas that extends rearwards from the line of stitching lies flat against the body. Also worth noting in my case: if I had fitted it like your lower photo, the whole top would have been 5-10 mm further aft and then the 'side flaps' would have been too far aft to fit with the frontmost turnbuckle.
Mike
Sunny South Africa
Yes, indeed ..that makes a good result and makes more sense to me.
post #5 of 11 (permalink) Old 06-04-2019, 01:38 AM Thread Starter
mudshark's Avatar
Baie dankie Mike, I fully get your point and the drawing helps a lot as well!
rgds,
George
mudshark is offline
post #6 of 11 (permalink) Old 06-04-2019, 02:25 AM
Dit is 'n plesier ... glad to help...
Where did you source your top? The one I got from Elvezio is great quality, but really needed a lot of thinking and fettling to get it to fit perfectly. Particularly the side flaps and the turnbuckles, where the fit was very marginal. It was a case of measure, adjust, measure adjust, measure, adjust, before committing to cutting the holes.
Another tip. Only glue the back top bow when you have it all fitted, but keep checking its position as it is an important reference point.
Mike
post #7 of 11 (permalink) Old 06-04-2019, 04:56 AM Thread Starter
mudshark's Avatar
Hi Mike, I sourced mine at Classic Alfa in UK, it had a little sticker on it with Italian text 'capote giulia lunga dopo il 59' so I assume who ever produced it is from Italy.
I for sure will a do a lot of trying and measuring before final glue stages.. !
Another question... the bars in the frame have tiny holes where the straps are to be mounted. I now notice these tiny holes are only on one side where I thought there were for yarn to tighten, so all the way through, but now think these are for very small screws to fix..?
mudshark is offline
post #8 of 11 (permalink) Old 06-04-2019, 05:22 AM
Hi George
When I stripped my frame I found that the straps had thin brass plates that were riveted through the straps and into the bow.
The 'original' straps on my car were (grubby) white, so may have been replaced before.
Mike
post #9 of 11 (permalink) Old 06-04-2019, 05:33 AM Thread Starter
mudshark's Avatar
great picture, thx Mike!
rgds,
George
mudshark is offline
post #10 of 11 (permalink) Old 06-04-2019, 11:57 AM
Darth Moderator
AlfistiSA's Avatar
The straps on my July '60 are attached with tiny self tapping screws - only 1 strap per side
Mike's car is 1.5 years newer than mine
Hartelyke groeten uit Zuid Afrika
Greig
Some 750's
Some 101's
Some 105's
Some others
AlfistiSA is offline
post #11 of 11 (permalink) Old 06-04-2019, 01:23 PM
Hi Greig
Very interesting. Is the single strap unique to the 1960 tops with the bolt down rear bar like yours or for all earlier tops?
Mike
