Weber vacuum take off - Alfa Romeo Bulletin Board & Forums
 4Likes
post #1 of 31 (permalink) Old 05-23-2019, 01:01 PM Thread Starter
NMS
NMS's Avatar
Hi
I have a 1964 Giulia spider with a later 1750 engine, and two Weber 40 DCOE 32 carbs.
Wanted to attach vacuum gauges to the carbs, to synchronize them.
The only port that I found is the one I marked in the first picture, and I removed the screw-in plug in the other two pictures.
Two questions:
1. Is this the correct port to measure vacuum?
2. I was surprised to find that is has a 5/16UNF-24 thread. Where can I find the correct take off adapter- I only found adapters with M6 thread, as in the last pic.
Naftali
NMS is offline
post #2 of 31 (permalink) Old 05-24-2019, 09:23 PM Thread Starter
NMS
NMS's Avatar
Anyone?
NMS is offline
post #3 of 31 (permalink) Old 05-24-2019, 10:02 PM
Gubi's Avatar
That's the progression hole cover. It appears that the non-emissions DCOE Webers (e.g., the pre-151 versions) don't have a vacuum takeoff. Which is a bummer as I was hoping to use it for a vacuum advance myself.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #4 of 31 (permalink) Old 05-24-2019, 11:06 PM Thread Starter
NMS
NMS's Avatar
I guess that makes sense.
Didn't really consider the possibility of the carbs not having a vacuum take off...
Thanks!
NMS is offline
post #5 of 31 (permalink) Old 05-25-2019, 03:30 AM
Depending on how dedicated you are to synchronizing, you could replace your rubber carb mounts with aluminum solid mounts and drill and tap for vacuum ports...
gprocket is offline
post #6 of 31 (permalink) Old 05-25-2019, 07:04 AM Thread Starter
NMS
NMS's Avatar
Your right. Thought about that, but I don't think I'm that dedicated...
Anyway, I believe that with our old engines (and inevitable cylinder to cylinder variations), the instruments' readings are only indications- after that you need a good mechanic's ear... So I don't think it's worth the effort.
NMS is offline
post #7 of 31 (permalink) Old 05-25-2019, 08:07 AM
Push hard and live
DPeterson3's Avatar
First...
I don’t recommend any form of vacuum or air flow measurement for synchronizing. This subject could get a several page treatise, but I never seem to have the mood and time simultaneously. A summary version...
Regardless of your method or religion, a good result depends upon a good installation. Float levels empirically confirmed, throttle shafts aligned, throttle plates correctly installed, throttle shafts not bent, no vacuum leaks etc. if that’s all ok....
All you really care about is the perfect match at idle. Even with Balogna’s vaunted precision, the airflow and fuel match at idle are so small that measuring the vacuum will, at best, get you started. The final adjustment has to be done based upon engine behavior.
With the engine off.
Start by backing out the idle speed screw such that the cable or rod-driven carb is fully closed (we’ll call that the primary carb). Adjust the synch screw with your finger touching the shaft of the primary carb and your eyes closely watching until you feel it move. The point you are seeking is when the secondary carb has fully closed and any more adjustment of the synch screw will lift the primary butterflies off of closed. With care, you can achieve all four butterflies fully closed simultaneously.
Screw in enough idle screw to keep your car running. Start the engine. Go drive around awhile.
With the engine fully warm and heat-soaked...
Set your idle mixture screws for best idle. Note how many turns each has. If/when your mixture screws give best idle and are equally threaded out, you have achieved true synchronization. This is the goal.
Unless you got a perfect match out of the box, you’ll have to make a series of small adjustments. Your “control” is idle speed. You should make all adjustments at the lowest idle speed your engine will maintain. If your adjustments force you to increase idle speed, you’ve gone the wrong way. Undo whatever you did and go the other way.
If one carb’s mixture screws are more extended than the other, its butterflies are POSSIBLY more open. Tweak the synch screw to slightly close them, reset all mixture screws, and note if you’ve gotten the mixture screws closer or farther from matching. After a round of adjustments, attempt to reset the idle speed lower. If you can, you’re going in the right direction. If you can’t, either you’ve gone in the wrong direction, or you’ve achieved a match. Idle mixture screw adjustments tell you the most with butterflies maximally closed.
You’re done when all four mixture screws have the same insertion, and your engine can maintain a very low, smooth idle. Assuming typical Alfa street cams, I’m used to achieving a 400-500 RPM idle. That’s generally proof everything is synched. Then, I reset the idle to a more typical 700-800 RPM.
Yeah, I’ve heard all of the points supporting flow and vacuum synchro methods. For these to actually achieve a best result over the above method there’s about 50 variables in the engine that must be perfectly identical across all four cylinders. Perfect. Not very, very close. Perfect.
There’s too many variables to think that measuring only one will achieve a synchronization.
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is online now
post #8 of 31 (permalink) Old 05-25-2019, 08:39 AM
carl750's Avatar
Mercury Sync tool adapters
Attached factory images show where adapters are connected.
carl750 is offline
post #9 of 31 (permalink) Old 05-25-2019, 10:22 AM Thread Starter
NMS
NMS's Avatar
Originally Posted by DPeterson3 View Post
First...
Great "summary version". It's comprehensive in my book! Thanks for the time you took to write it.
I agree 100%- you need experience and patience to tune old Alfas. Thought to get a helping hand from the vacuum readings, but I guess I'll do without it
NMS is offline
post #10 of 31 (permalink) Old 05-25-2019, 10:30 AM Thread Starter
NMS
NMS's Avatar
Very useful images, but they are Dellorto carbs.
Mine are Webers. Thanks.
NMS is offline
post #11 of 31 (permalink) Old 05-25-2019, 12:43 PM
Push hard and live
DPeterson3's Avatar
The full version would have to embrace a peer-reviewed technical paper I presented at a Canadian ISA meeting, more or less covering the fallacies of instrument calibration in pursuit of an accurate outcome.
It’s a simple concept that almost no one wants to understand.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #12 of 31 (permalink) Old 05-25-2019, 01:14 PM Thread Starter
NMS
NMS's Avatar
I would be very interested in reading the article.
Can you post it, or reference it?
NMS is offline
post #13 of 31 (permalink) Old 05-25-2019, 01:32 PM
Push hard and live
DPeterson3's Avatar
That’s been a dozen or so years ago, and I’m long retired. The paper was on how to calibrate an industrial pH sensor, but the broader issue was the fundamentally flawed method of focusing on one variable in a multi-variable problem, particularly when one of the variables is a human.
In a separate training session I gave to the technicians at a Bayer chemical plant, the senior, and very German, chemical engineer remarked at the end “I see that you are right, but I still disagree!”
German engineers tend not to recognize humans as a variable,
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #14 of 31 (permalink) Old 05-25-2019, 11:41 PM Thread Starter
NMS
NMS's Avatar
Great story!
NMS is offline
post #15 of 31 (permalink) Old 05-26-2019, 12:53 AM
I’m not sure why you couldn’t use your method WITH a manometer to help fine tune, Shirley that’s what everybody does?
Out of interest, what does the Alfa process document?
(I actually don’t know, and am looking for a fool proof process)
Craig_m67 is offline
Similar Threads
Bosch distributor with vacuum advance canister... What hose... sbadaro GT (1963-1977) 14 07-26-2018 04:05 PM
40 DOE Weber gasket vacuum leak? joerain Spider - 105 & 115 Series (1966-1994) 17 08-09-2012 02:57 PM
80-81 Weber Conversion Conundrums andy303 Carburetors, Fuel Injection & Air Intake 4 12-15-2009 06:27 PM
correct vacuum readings for 16v?? 76Alfasud5M Boxer Engined Alfa Romeos 3 01-01-2009 02:07 AM
Brake Booster or Vacuum Alfa_Todd Suspension, Steering, Brakes, Wheels & Tires 2 07-27-2006 08:00 AM
