750 Veloce oil pan numbers - Alfa Romeo Bulletin Board & Forums
post #1 of 7 (permalink) Old 04-14-2019, 06:07 PM Thread Starter
DaveB's Avatar
Have a 750 Veloce pan with an unusual number
Wondered if anyone n
Knows what the suffix means?
DaveB is offline
post #2 of 7 (permalink) Old 04-14-2019, 06:33 PM
Alleggerita's Avatar
looks like a magnesium pan
Alleggerita is online now
post #3 of 7 (permalink) Old 04-14-2019, 06:59 PM
squirrelman1's Avatar
my pan that looks like that is gawd-awful heavy. someone please inform my why it's angled ?
ones that got away: '57 Giulietta Spider, '67 TI Super, '74 GTV, '64 Giulia Spider, '72 GT Junior.
squirrelman1 is offline
post #4 of 7 (permalink) Old 04-14-2019, 07:14 PM
alfabits's Avatar
Because the Veloce engine sits at an angle so the Webers can clear the engine bay frame rails?
George Kraus
w ::
Portland, OR USA
e ::
AROO ALFA BITS NEWSLETTER EDITOR ::
ALFA ROMEO OWNERS OF OREGON (AROO) ::
1960 GIULIETTA SPIDER VELOCE
RESTORATION PHOTOS ::
ALFA BULLETIN BOARD BLOG ::
alfabits is offline
post #5 of 7 (permalink) Old 04-15-2019, 05:10 AM Thread Starter
DaveB's Avatar
I’m going to weigh this pan compared to a typical Veloce sump,
Regular Veloce sump is about 20 lbs I think.
DB
DaveB is offline
post #6 of 7 (permalink) Old 04-15-2019, 07:19 AM
ubach's Avatar
Dave,
My 750 Veloce pan (with baffles) weighs 23 lb.
Numbers on both parts are identical to yours.
Ulf
1957 Spider Veloce
IN VINO VERITAS
ubach is offline
post #7 of 7 (permalink) Old 04-15-2019, 08:08 AM
Gordon Raymond's Avatar
I don't know if this will help or add more confusion, but in parts books, there are 2 DIFFERENT part numbers for 750 Veloce sumps. Here is what I know from building speciality pumps for 750 Veloces.
Early 750 Veloce sumps are 3mm deeper than final production sumps. Early sumps would fit the oil pump bottom in the first picture below. Late production fit the shorter pump bottom pictured next. This pump was referred to as the '"replacement Veloce pump" and was an 11 tooth, short gear bottomed pump, referred to by engine builders in the late 50's early 60's as the "DEATH pump" as it failed very quickly in use due to inadequate idler pin support. Alfa redesigned the pump again for the 101-1300 along with the sump, a 101 casting number sump, back to being 3mm deeper once again.
I have seen 750 sumps with the SAME casting numbers but some 3mm shallower than others, these being late production. When did they change? I do not know, but by '59 they were shallow.
Gordon Raymond
Now:
Gordon Raymond is online now
Similar Threads
Wanted: 750 Giulietta Steel Oil Pan Front and Rear Straps kuni123456 Alfa Romeo Parts For Sale & Wanted 0 07-16-2018 08:21 AM
Where are all the Alleggerita Giuliettas... clemensh83 Giulietta & Giulia (1954-65) 17 10-24-2008 04:58 PM
Convention Concours Thread Chi Si Dici CAROC - Chicago Alfa Romeo Owners Club 71 06-23-2008 07:15 PM
Rotella v Mobil 1 Observations on New Motor Ish-Man Alfa Romeo Topics Not Covered Elsewhere 20 02-26-2007 08:50 AM
giulietta veloce oil pan 120 Alfa Romeo Parts For Sale & Wanted 1 02-21-2005 01:01 AM
