very hard front axle - Page 2 - Alfa Romeo Bulletin Board & Forums
post #16 of 17 (permalink) Old 02-26-2019, 05:31 AM Thread Starter
pescara's Avatar
@ Alex : don't tell anyone, in my old stock ....
@ Uncle : maybe, why the right part was OK and the left one, no ? Same parts, same supplier, same shims... but maybe a mistake of assembly from us.
Chris, in love with Alfa from...'68, but it wasn't always reciprocal !
pescara is offline
post #17 of 17 (permalink) Old 02-26-2019, 06:20 AM
divotandtralee's Avatar
Yep, there are enough variations to require a different load of shims. The best solution is not mess with the hard seat and reuse the old one unless you can clearly see a wear pattern. . The failure is usually attributed to the ball being bent. It the stem isn't bent a little scuffing from dirt shouldn't hurt anything as long as there are no raised burrs with can be polished with fine sand paper ....to take out the roughness but leave the scars alone. They just hold more grease like the slits and dimples in bronze bushings. Of course it goes without saying any "wobble" in the joint would require a new ball and a trial fitting as you go. It sounds like you got lucky on the other side. Luck trumps all other correctness.
divotandtralee is offline
Similar Threads
Source for Front Axle Nuts BostonBertone GT (1963-1977) 13 07-24-2013 06:36 AM
A sensation of oversteer? Geoman Spider - 105 & 115 Series (1966-1994) 83 05-12-2013 08:08 AM
For Sale: GIULIETTA 1300 SPIDER Complete front suspension, brake, rear axle desertdie Alfa Romeo Parts For Sale & Wanted 0 04-18-2013 02:29 PM
105 Brake hard lines DDS Spider - 105 & 115 Series (1966-1994) 3 09-18-2012 06:31 PM
Over 600 new old stock parts jamieandthemagi Alfa Romeo Parts For Sale & Wanted 2 07-21-2006 08:42 PM
