Heat shield - Alfa Romeo Bulletin Board & Forums
 5Likes
post #1 of 19 (permalink) Old 02-11-2019, 02:28 AM Thread Starter
Karter7's Avatar
Heat shield
I removed my exhaust heat shield as per attached photo for shipping to Australia as it appeared to be covered in a asbestos mat (inside of shield). Car is a 1963 101 spider.
A couple of questions:
1) is the matting usually asbestos?
2) what have you used in leiu as original shield is pretty curvy?
Thanks in advance
Daniel
Karter7 is offline
post #2 of 19 (permalink) Old 02-11-2019, 04:28 AM
GTD
GTD's Avatar
Yes
2) what have you used in lieu as original shield is pretty curvy?
Mineral wool products can be used but in reality, it is generally unnecessary .. the aluminium shield itself is sufficient to reflect the heat from the exhaust pipes.
As this area tends to accumulate road grime, it is easier to keep clean when there is a simple metal shield in place.
Alfa Sapiens
GTD is offline
post #3 of 19 (permalink) Old 02-11-2019, 08:50 AM
Lokki's Avatar
I have had good results with this company’s products
https://www.heatshieldproducts.com/a...ermal-barriers
71 Spider
Lokki is offline
post #4 of 19 (permalink) Old 02-11-2019, 11:38 AM Thread Starter
Karter7's Avatar
Yes
How do I safely remove the asbestos matting from thr shield which I still have?
Karter7 is offline
post #5 of 19 (permalink) Old 02-11-2019, 11:50 AM
Darth Moderator
AlfistiSA's Avatar
Hi Karter
Yes as the others have said, the original material is an asbestos woven mat - if it is intact and not powdering, then it's about as stable & inert as it's likely to get - years of dirt, oil & grime helps to bind it together. If you do clean it, then try just spraying a degreaser onto the mat & lightly washing it while wearing a face mask. Asbestos is nasty stuff if reduced to powder form and spread about in the air where you are breathing. In this matting & old roof sheets etc, it's basically inert until you start fiddling with it. Once you start scratching at the matting you will break down the fibers and release powdered asbestos into the air - this is illegal in your country & mine.... the laws and costs involved in disposing of asbestos are onerous, this is a case of "if it is't broken, then don't fix it" Please do take all precautions around it anyway.
I remake these from aluminium sheeting & use a modern self adhesive heat reflective & protective matting on the rear which is then further held into position by crimping over the edges. Yes it's got quite an S curve, it needs this to get around the exhaust branches, but when new the aluminium was quite soft so easily bent into shape by hand. 60 years later it's work hardened due to heat & vibration so not so easy to bend, whereas the new ones are soft and bend really easily. They will work harden over time.
Ciao
Greig
Karter7 likes this.
Some 750's
Some 101's
Some 105's
Some others
AlfistiSA is offline
post #6 of 19 (permalink) Old 02-11-2019, 11:52 AM
GTD
GTD's Avatar
Unless it was in ratty condition .. I would use it as is.
If you find you really must remove it, a hot pressure washer jet should peel it off without difficulty.
DO NOT attempt to sand or grind it off.
It may be easier to simply duplicate it.
I use stainless steel for re-pops .. it survives better than the aluminum original.
Karter7 likes this.
Alfa Sapiens
GTD is offline
post #7 of 19 (permalink) Old 02-11-2019, 12:07 PM Thread Starter
Karter7's Avatar
Originally Posted by AlfistiSA View Post
Hi Karter
Ciao
Greig
Hi Greg,
I think Iíll remake as I donít want to go near the old shield then.
What thickness alloy did you use?
Thanks in advance
Regards Daniel
Karter7 is offline
post #8 of 19 (permalink) Old 02-12-2019, 10:11 AM
Darth Moderator
AlfistiSA's Avatar
The original I copied was a little under 0.8mm, I've use the same or slightly thinner. I found thicker sheet too difficult to bend around the pipes and still make sure that it's not touching the branches.
I haven't tried stainless yet, will do that on the next one
Ciao
Greig
Karter7 likes this.
Some 750's
Some 101's
Some 105's
Some others
post #9 of 19 (permalink) Old 02-12-2019, 04:18 PM
I know you nsaidyou wont remove it yourself, but if you do wear a face mask, eye protection, gloves, hat, and after you finish put your clothing and hat in the washer by them self and shower and wash your hair
and you should be ok
alfajohn is online now
post #10 of 19 (permalink) Old 02-13-2019, 09:10 PM Thread Starter
Karter7's Avatar
Hi Alfajohn,
I pulled the heat shield off the car and double bagged it. Iíll make a new one out of alloy sheet.
I did use a face mask and gloves as a precaution but the matting is intact.
I just feel if you attempt to remove the asbestos from the heat shield there is a greater chance of spreading asbestos everywhere.
Even if you pressure blast it off, it will dry out and be everywhere. Not worth the risk in my opinion.
Thanks for the advice
Regards Daniel
Karter7 is offline
post #11 of 19 (permalink) Old 02-15-2019, 09:04 PM
My car was missing the shield.
Can someone post some photos, taken in various directions, of what the shield looks like.
I'll then fabricate one
Thanks, Mick
Fulvia 1600HF, Fulvia Sport Zagato (project), Giulia Spider Veloce (project)
OMWattsy is offline
post #12 of 19 (permalink) Old 02-16-2019, 11:04 AM
Hi Mick,
I made this pattern from a friend's Giulia Spider for my car along with material and fabrication suggestions from Bill Gillham. I cut old manila file folders to 8.5x11 inches and printed them out on the inkjet printer. Very easy to cut out of aluminum sheet. I may or may not pinch in heat barrier fabric.
Matthew Fox
1962 Giulia Spider
alfa62fox is offline
post #13 of 19 (permalink) Old 02-16-2019, 05:50 PM
zircoflex III
found that Zircoflex III was ideal. flexible yet self supporting. also it is a single material unlike aluminium with heat resistant additional coatings
https://www.zircotec.com/zircoflex/
cheers
mike
mikegoldthorpe is offline
post #14 of 19 (permalink) Old 02-16-2019, 05:56 PM
zircoflex III
used Zircoflex III for shield. flexible yet self supporting and is a single product unlike having to treat aluminium with heat absorbing additions
cheers
mike
post #15 of 19 (permalink) Old 02-16-2019, 07:04 PM
Barn101's Avatar
Thanks, Mick
Mick, here are some of my original '61 shield. They should give you an idea of the dimensions & angles with the above template. Hopefully they help you.
Barn101 is offline
Similar Threads
GTV Heat Shield angiegtv GT (1963-1977) 2 12-30-2017 04:11 AM
750-101(1600) heat shield question concept 101 Giulietta & Giulia (1954-65) 2 05-22-2017 05:46 AM
Heat Reduction Project 84gtv63l Alfetta & GTV6 (1972-1986) 11 10-06-2014 06:08 PM
replacement heat shield experience Bjorn S Spider - 105 & 115 Series (1966-1994) 31 05-09-2014 05:41 AM
S4 Heat Shield Mounting Points Vintre Spider - 105 & 115 Series (1966-1994) 16 02-14-2014 03:24 PM
