Heat shield - Page 2 - Alfa Romeo Bulletin Board & Forums
 4Likes
post #16 of 19 (permalink) Old 02-17-2019, 01:11 AM
Hi all,
Thanks for the pattern and photos
Much appreciated, Mick
Fulvia 1600HF, Fulvia Sport Zagato (project), Giulia Spider Veloce (project)
OMWattsy is online now
post #17 of 19 (permalink) Old 03-11-2019, 08:06 PM
jburning17's Avatar
Hi All,
Rather than start a new thread, I thought that it would make for better organization to add to this one.
I am going to fit a heat shield from Alfastop to a 750 normale. I could use some picture and information about how the horseshoe bracket should fit to the pedal box. Are there threaded holes in the pedal box or are there through bolts?
Jon
current: '57 spider normale
previous: '74 spider in that weird yellow color
I spend too much money on my car. It's Gordon's fault.
jburning17 is offline
post #18 of 19 (permalink) Old 03-15-2019, 05:50 PM
Barn101's Avatar
Originally Posted by jburning17 View Post
Hi All,
Jon
Jon,
I don't have installed parts on a car photos yet, but there are threaded nuts on my 101's bracket to attach the heat shield to it. The peddle box holes are not threaded to receive that bracket, it will need nuts, washers and bolts. Looks like 10mm bolts for it.
Not wanting to give out misinformation, if I'm wrong hopefully someone will chime in to correct or affirm the direction/placement of this bracket, but it lined up for me. I'm just getting started on my first reassembly, so I'm still sorting out where parts go since I didn't take this Spider apart and I don't have a spare original car to help out. I've found not all parts like this are shown in my original parts book, or shop manual sometimes. Hopefully these help.
Barn101 is offline
post #19 of 19 (permalink) Old 03-18-2019, 12:40 PM
Darth Moderator
AlfistiSA's Avatar
6mm bolts with a number 10 spanner.
The straight edge of the shield bolts onto the vertical body flange alongside the pedal box in the drivers side front wheel well. The body of the shield bolts to the metal bracket which is in turn bolted to the nose of the pedal box
Not all pedal boxes are drilled for the little metal bracket
You basically feed it in between the master cylinder and the down pipes and wiggle and bend it into a suitable shape to curve around the pipes
Aye
Greig
Karter7 likes this.
Some 750's
Some 101's
Some 105's
Some others
AlfistiSA is offline
Similar Threads
GTV Heat Shield angiegtv GT (1963-1977) 2 12-30-2017 04:11 AM
750-101(1600) heat shield question concept 101 Giulietta & Giulia (1954-65) 2 05-22-2017 05:46 AM
Heat Reduction Project 84gtv63l Alfetta & GTV6 (1972-1986) 11 10-06-2014 06:08 PM
replacement heat shield experience Bjorn S Spider - 105 & 115 Series (1966-1994) 31 05-09-2014 05:41 AM
S4 Heat Shield Mounting Points Vintre Spider - 105 & 115 Series (1966-1994) 16 02-14-2014 03:24 PM
