Early 750 drivshaft - Page 3 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #31 of 44 (permalink) Old 04-14-2019, 11:45 AM
Darth Moderator
AlfistiSA's Avatar
Hello Bjorn & Luca
Christmas has arrived for your tunnel cases...
5 new ones, the front one is the original. My engineering friend had to buy a 20x1 tap for the internal thread
Send me a PM with your postal details - ditto anyone else needing one
Ciao
Greig
Some 750's
Some 101's
Some 105's
Some others
AlfistiSA is offline
post #32 of 44 (permalink) Old 04-14-2019, 12:42 PM
Thanks Greig,
Not sure but if made with a smaller bulb (I. Believe 18.5 mm) it could probably be used with a later style driveshaft.
Reed
RWCearley is offline
post #33 of 44 (permalink) Old 04-14-2019, 01:04 PM
Thanks Greig
Looks perfect!
PM sent
//Bjorn
Giulia Sprint GT -65
Giulietta Sprint 750B -55
Alfabjorn55 is offline
post #34 of 44 (permalink) Old 04-15-2019, 09:01 AM
dea
Thanks gor the good new!
Only some questions :
Which kind of carbon steel used ?
Same size and weight of the original part?
Why is gold zynched?
Would be pissible to buy the original sample?
Price?
Thanks!!!
dea is offline
post #35 of 44 (permalink) Old 04-15-2019, 12:57 PM
Darth Moderator
AlfistiSA's Avatar
EN8 steel, not hardened, but neither were the originals - the end of the driveshaft has a soft brass bush in it, so the pawl doesn't need to be harder than it is. They can be hardened if required.
Not sure why you would want the original, it has a flat spot on the round end which must have happened when the Guibo started to break down and the nut end was pressed up against the inside of the driveline bush plus the nut section has a few light scars from spanners, the reproduction ones are better as the end is round and true.
The engineering works yellow passivated them - they were originally cadmium plated, but this process is getting harder to find due to environmental issues. the original had light rust on the surface, it's under the car, deep inside the gearbox yoke and is covered by the Guibo or donut. I can spray one to replicate the original.
Ciao
Greig
Some 750's
Some 101's
Some 105's
Some others
post #36 of 44 (permalink) Old 04-15-2019, 01:50 PM
dea
Ok, so let me kmow how much. I want to buy the original and one new repro. Both of them.
Grazie,.Luca.
dea is offline
post #37 of 44 (permalink) Old 04-16-2019, 09:21 PM
Darth Moderator
AlfistiSA's Avatar
They cost me ZAR 1500 each or 95 Euro, you can have them at cost + postage in a bubble envelope - I will price this for you
Paypal is good - I will give you the address to use via PM
Ciao
Greig
Some 750's
Some 101's
Some 105's
Some others
post #38 of 44 (permalink) Old 04-17-2019, 08:18 AM
Andrew's Avatar
Beautiful work. Wish I needed one.
Andrew
Andrew is offline
post #39 of 44 (permalink) Old 04-19-2019, 12:19 AM
Hello again Greig
I don't feel confortable with AlfaBB's Control panel for PM's..
Can't see if my PM's has been sent
My "Sent" folder is empty..
Did you received the latest with my adress etc?
best regards
Bjorn
Originally Posted by Alfabjorn55 View Post
Thanks Greig
Looks perfect!
PM sent
//Bjorn
post #40 of 44 (permalink) Old 05-01-2019, 08:38 AM
dea
Hi, I'd want to know another info : which is the size of the exagon? mm.32 or mm.27 ?
Thanks in advance,Luca.
dea is offline
post #41 of 44 (permalink) Old 05-01-2019, 09:46 AM Thread Starter
carl750's Avatar
Sorry, I don't understand what you mean by "exagon"
carl750 is offline
post #42 of 44 (permalink) Old 05-01-2019, 10:54 AM
Darth Moderator
AlfistiSA's Avatar
Luca means Hexagon, the size of the nut = 32mm
Shipping via courier internationally works out to 29 Euro in bubble wrap in a box to your door
Ciao
Greig
Some 750's
Some 101's
Some 105's
Some others
post #43 of 44 (permalink) Old 06-03-2019, 10:41 AM
Just to let you know that tunnelcase for 00367 now is equipped with correct Pawl Nut.
Thank you all for your help
//Bjorn
post #44 of 44 (permalink) Old 06-03-2019, 11:10 AM
Darth Moderator
AlfistiSA's Avatar
Hey Bjorn that looks really good, glad the nut arrived safely
Ciao
Greig
Some 750's
Some 101's
Some 105's
Some others
