Fuel additives - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By kuni123456
post #1 of 8 (permalink) Old 07-29-2018, 08:39 PM Thread Starter
Fuel additives
Does anyone recommend using fuel additives In older cars, and if so which ones. Also any thoughts on octane boosters and using ethanol free gas.
John Ciab is offline
post #2 of 8 (permalink) Old 07-30-2018, 03:16 AM
divotandtralee's Avatar
If you have a ping... which might be the reason you posted.. in a Normale.. it's probably caused by ignition timing slightly off, wrong plugs/gap, or driving around lugging the engine in the wrong gear. I've never had the occasion to use octane boosters and never needed them in Veloces or Normale's. and use ethanol. The key to ethanol use (and it's hard to avoid) is to refuel in small doses that you are going to use for occasional driving. Plan on the amount you expect to use say over a 3 month period. A long trip.. top it off full. You will never have a problem with ethanol that way. Winter storage, I always added stabilizer to a tank with less than 2-3 gallons in the tank and freshened it up on the first drive after winter. Never an issue with rust or stale gas..Just my experience. Some folks swear by octane boosters and lead additives as 'multi-vitamins" for their engine. I don't use 'em.
Use only Premium gas. Enjoy your new car.
divotandtralee is offline
post #3 of 8 (permalink) Old 07-30-2018, 07:02 AM
BB Janitor
ghnl's Avatar
I agree that if driven regularly then ethanol laced gas is not a problem. If your car has old rubber gas hoses they might be affected by the ethanol. But if they're that old they're probably due for replacement anyway.
Use the octane your engine requires. Higher octane than needed won't hurt it but it'll lighten your wallet faster.
The only additive I use on occasion is Chevron Techron - it is supposed to help keep the fuel injectors clean.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #4 of 8 (permalink) Old 07-30-2018, 07:35 AM
pescara's Avatar
I don't use additive in Alfa, never. I used 98 fuel only from a premium brand.
Just my experience. From 15 years now, no problem with valves seats. My engines are always complete overhauled before I use them.
Chris
Chris, in love with Alfa from...'68, but it wasn't always reciprocal !
pescara is offline
post #5 of 8 (permalink) Old 07-30-2018, 08:55 AM
Tom Frasca's Avatar
I add 4 oz. of marvel mystery oil, every time I fill up, I have access to alcohol free gas as well-Premium fuel. That said, on the occasion I use ethanol
blends, there is no noticeable difference in performance.
Tom Frasca is online now
post #6 of 8 (permalink) Old 07-30-2018, 09:08 AM
Alfajay's Avatar
I don't think performance is the issue with ethanol; the issues are:
- it's lack of lubricating qualities (which is why enthusiasts add oil to their gas)
- the way it attacks rubber components
- its short shelf life (or "tank life"). People I know who have large car collections generally use aviation gas. Their cars may go years between fill-ups, and they claim non-ethanol gas stays fresh longer.
I use this stuff:
It seems like a light oil, probably similar to Marvel. Costs ~ $25 a gallon, which will probably last me a lifetime.
Alfajay is offline
post #7 of 8 (permalink) Old 07-30-2018, 09:35 AM
Tom Frasca's Avatar
@Alfajay ...Good point at the end of the driving season or storage the fuel is ethanol free.
post #8 of 8 (permalink) Old 07-30-2018, 09:42 AM
I recommend using Ethanol Shield for cars that use gasoline mixed with ethanol. The cars that are not driven once a month can develop carburetor problems unless you use a gasoline preservative. I have found that Ethanol Shield works for my Sprint Veloce as well as for small gasoline engines. You can buy racing fuel that does not contain ethanol but, the gas costs about ten dollars per gallon and gasoline preservatives are much less expensive. I thought about using aviation gas but, that is not legal for cars.
divotandtralee likes this.
kuni123456 is online now
