Looking for low temp screw in thermostat - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Gubi
post #1 of 9 (permalink) Old 12-03-2016, 01:41 AM Thread Starter
Hi guys
Any one have ..?
Do you know where i can buy?.
My car is runing on 90c here on winter ..i belive in summer it will get hot..
So i need 70 c or in the range
domo75 is offline
post #2 of 9 (permalink) Old 12-17-2016, 01:39 AM Thread Starter
Hi
No comunt..
Any one have a solution the i can run my car not so hot and keep the originaly look??
domo75 is offline
post #3 of 9 (permalink) Old 12-17-2016, 06:44 AM
101/105guy's Avatar
I haven't seen a low temp one......
If your car is running hot or cold and the T-stat is funcioning correctly, you have some other problem.
Take the car to a quallified mechanic and have him check it.
'64 Guilia Spider
'67 GTV
'68 Giulia Super
101/105guy is offline
post #4 of 9 (permalink) Old 12-17-2016, 07:54 AM
concept 101's Avatar
Send a message via Skype™ to concept 101
Originally Posted by domo75 View Post
Hi
No comunt..
Have you checked your radiator? 50-60 year old radiator core could hamper the water flow needed due to the deposits/sediments that have gathered on the inside over the years.....
Dennis
concept 101 is offline
post #5 of 9 (permalink) Old 12-17-2016, 08:30 AM Thread Starter
Hi all
The rediator is completly rebulid with new cores..much biger core.
I want to tell again..
The car not over heated..its working on 90degree its winter here..
And i say thet in the hot summer here the car will over heated..
Btw
All the engine and components are newly rebuiled..
Almost every thing is brand new.
Now any ideas..??
domo75 is offline
post #6 of 9 (permalink) Old 12-17-2016, 09:01 AM
divotandtralee's Avatar
How are you measuring the temperature? Did you bleed any air in the system? Have you experimented without a thermostat and measured the temp? Did a professional mechanic diagnose you need a different thermostat? The nice thing about cooling systems is they work all the same unless it is a VW Beatle. ANY mechanic will diagnose this in a heart beat. I doubt your thermostat is the answer. If it was, it wouldn't be so difficult finding another one that suits your temp range search.
divotandtralee is online now
post #7 of 9 (permalink) Old 12-17-2016, 09:10 AM Thread Starter
My is after a complete restoration one and helf year..
The mechanic check id
domo75 is offline
post #8 of 9 (permalink) Old 12-17-2016, 09:10 AM Thread Starter
The restoration of the car took 1.5 years..i just finished two weeks ago
domo75 is offline
post #9 of 9 (permalink) Old 12-17-2016, 09:58 AM
Gubi's Avatar
That's not how a thermostat works. A cooler thermostat won't prevent overheating as temperatures get warmer. Thermostats are fully open by 95C or whatever: at engine temperatures above that they basically have no effect.
If your car is actually running too warm, you have some other issue besides the thermostat.
divotandtralee likes this.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
