Performance Replacement Brakes for Giulia Models; - Page 4 - Alfa Romeo Bulletin Board & Forums
 14Likes
post #46 of 46 (permalink) Old 05-05-2019, 01:28 PM
Alfissimo Int.'s Avatar
Time for a new thread me thinks!
Yeah, I think there is partial truth to your claims but I am not sure you are 100% correct as there is information supporting both. It's difficult to fully believe your claims without evidence.
I do not believe the Giulia's roofline is too high for a spoiler on the trunk lid. The spoiler I speak of is the OEM spoiler nothing else. I am not speaking of anything aftermarket.
"Spoilers are used primarily on sedan-type race cars. They act like barriers to air flow, in order to build up higher air pressure in front of the spoiler. This is useful, because as mentioned previously, a sedan car tends to become "Light" in the rear end as the low pressure area above the trunk lifts the rear end of the car."
"Where most road cars (using your terminology here.. ) get into trouble is the fact that there is a large surface area on top of the car's roof. As the higher pressure air in front of the wind screen travels over the windscreen, it accelerates, causing the pressure to drop. This lower pressure literally lifts on the car's roof as the air passes over it. Worse still, once the air makes it's way to the rear window, the notch created by the window dropping down to the trunk leaves a vacuum, or low pressure space that the air is not able to fill properly. The flow is said to detach and the resulting lower pressure creates lift that then acts upon the surface area of the trunk. This can be seen in old 1950's racing sedans, where the driver would feel the car becoming "light" in the rear when traveling at high speeds. See the diagram below."
"Not to be forgotten, the underside of the car is also responsible for creating lift or down force. If a car's front end is lower than the rear end, then the widening gap between the underside and the road creates a vacuum, or low pressure area, and therefore "suction" that equates to down force. The lower front of the car effectively restricts the air flow under the car. See the diagram below."
"What all these "ideal" attributes stack up to is called the Drag coefficient (Cd). The best road cars today manage a Cd of about 0.28. Formula 1 cars, with their wings and open wheels (a massive drag component) manage a minimum of about 0.75.
If we consider that a flat plate has a Cd of about 1.0, an F1 car really seems inefficient, but what an F1 car lacks in aerodynamic drag efficiency, it makes up for in down force and horsepower."
Aerodynamics
Anyway, might want to start a new thread and see if you can get some folks in the field to respond!
Jason Minos
New: +1 619-209-0715
e-mail:admin at alfissimo.com
San Diego, CA
1989 Spider Quad. Gone
2010 Touareg TDI
2017 Giulia Ti Sport Q4, Trofeo, Leather package(red), 19X8, 19X9.
Alfissimo Int. is offline
Similar Threads
Changing 164 master cylinder/bleeding brakes Alfisto Steve 164 & 168 (1991-1995) 77 07-12-2019 03:38 PM
Alfsito Steve's daily blog Alfisto Steve 164 & 168 (1991-1995) 84 12-03-2017 05:35 PM
2008 Autodelta 159 J4 2.2 C In Detail smestas Alfa Romeo Topics Not Covered Elsewhere 4 06-26-2008 09:18 AM
Hemmings Article Highlighting Moderator Anthony, His Brother, and Racing Pat Braden Alfa Romeo Topics Not Covered Elsewhere 3 07-30-2007 09:07 AM
Super Seat Replacement between Early and Late Models alfa2go Sedan (1962-1977) 6 07-01-2006 01:08 AM
