keyless ignition? - Page 4 - Alfa Romeo Bulletin Board & Forums
 6Likes
post #46 of 53 (permalink) Old 03-09-2019, 06:09 AM
Originally Posted by Johnalfa View Post
Unfortunately the Giulia ZF 8speed is NOT easy to unlock if the engine is not running. It requires that a special bolt be inserted into a lever underneath the car. First problem is the bolt is not supplied with the car. Second problem is that insertion requires reaching under the car. Would you want to try that on the side of a busy highway? Love the Giulia; just wish more thought had been given to emergency service procedures.
That's not related to keyless entry or keyless start. If you have your fob you can get into the car, start the engine and drive away, same as if you had a key entry and start. You open the fob, extract the metal emergency key and use that to enter the car, placing the fob on the designated spot will allow you to start the engine and disable the alarm.
The procedure you describe is to deal with the no key at all situation or transmission control failure. It's complex because it isn't needed unless you gave a serious fault. Then you shouldn't be driving the car anyway.
Obviously you don't want to make it too easy to take the transmission out of P without the key.
1991 Alfa Romeo 164L 5 spd
Michael Smith is offline
post #47 of 53 (permalink) Old 03-09-2019, 07:36 AM
Johnalfa's Avatar
Michael, I was responding to your comment that on your Jaguar it's easy to unlock the ZF. Perhaps you could enlighten us as to how the British do this?
johnalfa
2018 Giulia TI
1988 Milano Gold Automatic (new arrival)
Previously Owned: 76 Alfetta GT, 81 Spider, 88 Milano, 89 Spider, 94 164LS (totaled 3/20/19)
Johnalfa is offline
post #48 of 53 (permalink) Old 03-09-2019, 12:35 PM
Sorry. To the rear of the gear selector segment of the console is a removable trim panel. Under that is a lock, operated using a flat blade. I've used a dime. That frees up a lever connected to the Park pawl inside the transmission. There is a red fabric strap connected to the end of this lever, you pull that upwards and the transmission brake is unlocked i.e. the pawl is pulled out of the transmission lock in the same fashion as selecting P would do. The transmission is then in neutral and the car can be moved or towed.
This feature is part of both the 6 spd and 8 spd ZF transmissions. I guess different car makers access this feature differently. Jaguar utilizes this provision from the interior of the cabin.
Subsequently the awd feature obstructed this access point so a cable was run up into the engine compartment and connected to a similar release device operated by hand.
post #49 of 53 (permalink) Old 03-09-2019, 06:09 PM
Johnalfa's Avatar
Thanks for the clarification. If only Alfa had done something similar! BTW I understand that the Euro diesel Giulias do have some variation but for whatever reason it isn't installed in the gasoline models. Pity.
johnalfa
2018 Giulia TI
Johnalfa is offline
post #50 of 53 (permalink) Old 03-10-2019, 12:34 PM
PSk
Cause found: https://www.9news.com.au/2019/03/10/...arpark-mystery
Shows how easy it is to affect these stupid, unnecessary systems. Don't even need to steal anything. Wish I had been there, parked in my old fashioned 1750/156v6 and with a simple thing like a "key" unlocked my car, turned on the ignition and started the engine, and then just drove away in seconds ... maybe I should take out a patent for a mechanical device that permits entry and operation of an automobile
'71 1750 Series 2 GTV:
PSk is offline
post #51 of 53 (permalink) Old 03-10-2019, 01:55 PM
So an Australian government regulatory failure means keyless entry in North America is stupid. The logic of that argument escapes me.
Your old fashioned key locks are easily defeated with a slide hammer or even a pair of barbers scissors in some cases.
As I pointed out, those Aussie car owners could as easily have used their metal key and driven away also.
Keyless entry, keyless start are very convenient, reliable and more secure than any hard key system.
post #52 of 53 (permalink) Old 03-10-2019, 03:12 PM
PSk
Hackers and thieves don't care about legistration, but you keep beating on about how awesome new cars are with their unnecessary features
Keyless entry is as useful as tits on a bull. My father's brand new car has it. He's never sure if the car is locked or not, and he embraces new tech.
PSk is offline
post #53 of 53 (permalink) Old 03-10-2019, 04:23 PM
If you don't like new cars that's fine but they're all coming with these features you don't like. I'm curious why you keep expressing your dislike on threads intended to assist owners or potential owners of these new fangled cars.
Tell your dad to simply "lock it again" if he isn't sure. It'll flash lights or something similar if you try to relock an already locked car. Some keyless entry cars will even lock the car for you even if you press the unlock button but fail to try to open a door or the trunk lid. Clever eh?
Similar Threads
Centerline ignition wire replacement set Spud Engine Repair, Diagnostics & Rebuilding 5 07-02-2018 09:18 AM
123 Ignition - wrong ignition parts or even ignition for my 2000 GTV? Che Electrical, Chassis & Lighting 4 09-17-2017 10:31 PM
1979 Dead ignition ssheldon Electrical, Chassis & Lighting 0 04-15-2017 07:27 PM
Nology Hotwires ecohen2 Spider - 105 & 115 Series (1966-1994) 12 07-03-2009 10:32 AM
URGENT help needed for ignition switch wiring Matthew K Alfetta & GTV6 (1972-1986) 11 03-11-2007 04:49 PM
