Dust cap on clutch rotates - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 05-21-2019, 09:46 PM Thread Starter
I have a strange sound coming from the transmission. It is a rattling squeeqing sound, especially when disengaging the clutch or when motorbreaking.
I now noticed that the dust cap (7) is loose and actually can rotate. That does not seem right to me. Anyone knows how that one should be fitted?
peral is offline
post #2 of 5 (permalink) Old 05-22-2019, 05:47 AM
Richard Jemison
Alfar7's Avatar
Dust Cap
It is only pressed on the Giubo mount.
You can try cleaning its mount area with a wire brush and brake clean and epoxying it back in place. Use only JB Weld (Not the JB "Quick" formula)
Best & permanent for sure is to unbolt the flange (it will slide off of the splines) and have it welded to the flange.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #3 of 5 (permalink) Old 05-22-2019, 09:21 AM Thread Starter
Thanks! That makes sense.
I was actually not sure whether the intent was that it should rotate with the yoke, or be fixed to the clutch housing.
From your message I understand that it should rotate. I will try the quick solution and hope it survives the summer.
peral is offline
post #4 of 5 (permalink) Old 05-23-2019, 05:41 PM
Jim G's Avatar
Number 7 is held down by the yoke. Your yoke is probably slightly loose since 7 is able to move.
Jim G is offline
post #5 of 5 (permalink) Old 05-24-2019, 12:33 AM Thread Starter
If the yoke is slightly loose, then that would mean that the flywheel of the clutch is somewhat free to move axially and perhaps vibrate and rattle about. And that would be different with clutch engaged/disengaged or accellerating/decelerating, as I have noticed, right?
peral is offline
Similar Threads
Broken Clutch Pivot jcslocum Spider - 105 & 115 Series (1966-1994) 91 04-18-2018 06:27 PM
clutch pedal feel and operation mcola Spider - 105 & 115 Series (1966-1994) 27 09-10-2013 08:17 PM
Clutch mystery Gary73Super Gearbox, Transaxle, Differential & Propshaft 22 12-16-2008 05:18 PM
Clutch failed on my 164LS alfa_164 164 & 168 (1991-1995) 8 12-03-2008 06:29 PM
WTB: Rubber Dust Civer for Mechanical Clutch alfajagowner Alfa Romeo Parts For Sale & Wanted 0 04-14-2007 06:33 AM
