Floppy Reverse/5th fork - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 05-15-2019, 05:19 PM Thread Starter
I’m reassembling my Alfetta gearbox with new (used) reverse gears and have a question about the fork that holds the reverse idler gear. It wants to simply hang down. I realize when it’s all together, the idler gear will be on a shaft which will also hold the fork in place, but concerned about how the assembly will go together if the fork won’t stay in place.
Is this normal? Any recommendations when installing the front casing?
John
79 Sprint Veloce Mille Miglia
19 Giulia Ti Sport AWD
AlfaJGD is offline
post #2 of 3 (permalink) Old 05-15-2019, 08:04 PM
Richard Jemison
Alfar7's Avatar
Dangling Fork
It`s normal, but not a problem.
When assembling transaxles and transmissions, everything comes together far easier with the trans standing vertically..
The fork will stay in place with the small idler gear in it while the front cover is slid down in place. Same for inserting the gear assembly & center bearing carrier into the rear section, as well as putting on the rear cover on a transmission.
On the transmissions the two roller bearings on the main and layshaft, will stay tight in their inner race (which should be heavily greased with thick axle grease to keep them there) while the rear tower cover is slid in place...
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is online now
post #3 of 3 (permalink) Old 05-16-2019, 01:59 AM Thread Starter
Thank you.
AlfaJGD is offline
Similar Threads
Spongy Clutch VWmeetsALFA Spider - 105 & 115 Series (1966-1994) 14 07-26-2015 09:56 AM
'88 Alfa Spider Clutch Fork question kingslandauto Spider - 105 & 115 Series (1966-1994) 62 03-16-2011 02:17 PM
1987 Alfa Spider Clutch Fork Removal C.Tanner Spider - 105 & 115 Series (1966-1994) 4 06-14-2009 03:29 PM
Positioning the Shifter Fork on it's Rod. MarcoGtv6 Gearbox, Transaxle, Differential & Propshaft 3 03-23-2007 06:38 AM
Clutch fork problem Ngaio75 Milano/75 (1985-1993) 6 12-02-2005 12:48 PM
