Gearbox assembly question - Page 2 - Alfa Romeo Bulletin Board & Forums
post #16 of 22 (permalink) Old 06-16-2019, 04:25 PM
Richard Jemison
Alfar7's Avatar
Patterning the contac\t area.
FWIW: I use white lithium grease.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #17 of 22 (permalink) Old 06-17-2019, 02:57 AM Thread Starter
Originally Posted by CatellusEng View Post
My apologies for coming late to this thread -- and late to the world of Alfa Romeos! My experience has been 23 years of service to another European marque's transmissions. My thoughts, please take with as many grains of salt as you wish.
Unfortunately the method of bluing will not give you meaningful results. The problem is that taking a pattern as you've done does not simulate how things will actually load up and center under engine load: with the engine pushing one way, the road forces and drive train friction pushing the other. These forces moves the contact center on the pinion and ring gear teeth. When properly measured by the factory (well, the ones I am familiar with) to minimize mechanical noise, the pinion depth is done in a rig that creates load.
Normally my experience has been that, barring particular circumstances, you do not need to measure and adjust pinion depth. The particular circumstances that would make it desirable to measure depth include changing the ring-and-pinion set, machining to the case, or of course some previous service that made a mistake in shimming (and that happens...).
Kudos to you for measuring with a CMM! I hope this is helpful and good luck with the project. It seems (from my brief acquaintance) that getting quiet running of Alfa pinions is a persistent problem.
You're not late, you are perfectly on time, many thanks for your reply.
In the particular case of this box, I don't know how it was done at the factory, but I do know that the pinion does come marked with a number (in cents of mm) which can be used to reset the depth to the correct factory value.
However I don't have the tools which would allow me to do this.
Failing that I can only try to reassemble it back to what it was before, a state at I know wasn't producing any noises or anything out of the ordinary.
I did take care to measure it in the most accurate way I could access, thanks to a friendly colleague at work who helped me out.
I was very surprised to see the depth change so much, I have no explanation for that. I did notice the shim was quite heavily marked, it had these deep grooves (I could feel them with my nail) which only went away after I took about 0.03 to 0.04 on each side of the shim. You can still see a trace of it in this photo:
This was a little surprising because the shim sits between the two flat surfaces of the 4th gear inner race and main bearing race as seen here:
I know someone had opened this box before so who knows...
Either way, regardless, the depth is now set to what it was before (within tolerance), the pattern looks okay-ish so I think this will be it untill the car goes back on the road...
mistamun is offline
post #18 of 22 (permalink) Old 06-17-2019, 04:50 AM
Jim G's Avatar
If this is a 3.0 liter gearbox. They were known for wearing the shim you mentioned in the previous post. It was quite common to see this.
Back in the day. We would go into the gearbox and measure the inside lip. The part of the shim that didn't have any wear on it and order a new shim of the same size.
As to why your measurement change. I don't understand that either. As the parts you replaced would not change the depth.
Jim G is offline
post #19 of 22 (permalink) Old 06-17-2019, 06:09 AM Thread Starter
Thanks Jim,
This is a 2.5L box.
What you're saying is the loads on the 3L would be big enough to turn the bearing races and the shim on the shaft? Nice!
mistamun is offline
post #20 of 22 (permalink) Old 06-17-2019, 07:54 AM
The grooves in the shim are almost certainly because the bearing has spun. Take a look at the walls of the case where the bearing sits: you'll see signs of its turning. If there is still decent interference between the outer race and the case, you can use a bearing / shaft adhesive aka. green Loctite to lock the race into place. Otherwise it is probably best to source a different case.
I have not found a source / alternative for the pinion shims, which I measure to be 61.0 x 70.8 mm. I do have a source for the differential carrier bearing shims. Anyone know of a source for the pinion shims?
Kevin
Catellus Engineering, Inc. - http://catellusengineering.com/
CatellusEng is offline
post #21 of 22 (permalink) Old 06-18-2019, 12:42 AM Thread Starter
Hi Kevin,
Thanks for the input, in the case the shim I'm talking about is the shaft shim behind the inner race on the pinion side, not the behind the outer bearing race on the case.
No idea where I would source it though... Make one?
Cheers,
Pedro
mistamun is offline
post #22 of 22 (permalink) Old 06-18-2019, 06:08 AM
Hi Pedro, got it, and that's the critical one for setting pinion depth, what Alfa labels the S1 shim. The other shim, S2, 28.5 x 40 mm, sets preload on the two taper roller bearings. Cheers,
Kevin
Similar Threads
Question regarding gearbox spacer..... Alfa1277 Spider - 105 & 115 Series (1966-1994) 20 04-29-2019 09:05 AM
Milano/75 LHD Pedal Assembly Removal Question 75evo Milano/75 (1985-1993) 1 07-29-2018 12:46 PM
Alfa 75/Milano suspension and gearbox in a '80 Alfetta 2000 sedan fiat cc Alfetta & GTV6 (1972-1986) 11 06-22-2012 08:07 AM
Gearbox cross member question Alex GT (1963-1977) 4 05-28-2007 03:09 PM
Wheel Bearing assembly question jjb Suspension, Steering, Brakes, Wheels & Tires 4 03-17-2005 11:56 AM
