Replace reverse gears? - Alfa Romeo Bulletin Board & Forums
post #1 of 1 (permalink) Old 04-29-2019, 05:54 PM Thread Starter
A few years ago at the Pittsburgh Vintage Gran Prix, I was parked on the lawns and had to back out of a spot. Backing up, uphill in the grass, I heard a horrible noise from the back. Ever since, my Alfetta has had an ugly rough noise while backing up. It worked on the level pavement but was terrified of backing up under any load.
I finally got the gearset out today and see there is a broken tooth on the mainshaft reverse gear. Obviously Iíll need a replacement. What about the idle gear and the driven shaft reverse gears? There is clearly wear and some damage, but since reverse isnít used like the other gears, do they need replaced?
John
AlfaJGD is offline
Similar Threads
Reverse switch svib Gearbox, Transaxle, Differential & Propshaft 13 03-15-2018 09:47 AM
Reverse Idler Gear Wear Vintre Gearbox, Transaxle, Differential & Propshaft 14 03-04-2017 08:19 PM
Knocking noise in reverse, Milano Milanoguy Gearbox, Transaxle, Differential & Propshaft 0 09-22-2016 06:38 PM
mixing transmission gears alphil Gearbox, Transaxle, Differential & Propshaft 11 02-16-2016 12:07 PM
Shifter difficulties (reverse) AlfaEmitter Spider - 105 & 115 Series (1966-1994) 11 07-28-2011 09:46 PM
