Axle half shaft speedi-sleeve? - Alfa Romeo Bulletin Board & Forums
LinkBack Thread Tools
Old 04-29-2019, 09:47 AM Thread Starter
Gubi's Avatar
So my half shaft has some damage where the seal rides that's causing it to leak. Anybody have any success using a speedi-sleeve for this application? I figure if they make them in that size I should be able to just get it down on top of the retaining ring, covering the damage.
Alternatively, any other fix, or is it best to just source a new axle?
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
Old 04-29-2019, 11:45 AM
goats's Avatar
See my earlier post on this same subject
goats is online now
Old 05-20-2019, 10:05 PM
crackie's Avatar
Tom-
Were you able to figure this out by inspecting the axle shaft or did you put it all back together and find out it still leaked?
I'm going to be putting mine back together this week and wondering if I should be looking for something on the axle shaft before I do.
--Scott
Current: 85 GTV6, 69 Duetto, 17 Giulia, 74 GTV
Past: 65 Giulia Sprint GT, 77 Alfetta, 79 Alfetta, 87 Milano Gold, 74 GTV (Euro)
crackie is offline
Old 05-21-2019, 05:01 AM Thread Starter
Gubi's Avatar
Well, I munged it up getting the ring off, so it was pretty obvious. If you were less ham-handed than me you’re probably fine.
1974 GTV
1991 Spider
Gubi is online now
Old 05-21-2019, 09:42 AM
crackie's Avatar
Yeah those rings are tough. Only thing that saved me from the same was learning from you doing it before me.
--Scott
crackie is offline
Similar Threads
Rear Axle / Differential Teardown & Reassembly crackie GT (1963-1977) 45 07-14-2019 07:43 PM
Replacing a Burman Shaft-Type Steering Box Seal In-Situ Roadtrip Spider - 105 & 115 Series (1966-1994) 64 03-25-2019 06:17 PM
How to remove the rear hub bearing from the rear axle shaft? onboroALFA GT (1963-1977) 5 08-11-2018 01:13 AM
Journey into the center of a heater fan motor - S1 and S2 Junior mechanical debugging Inner Circle Spider - 105 & 115 Series (1966-1994) 0 05-05-2011 01:10 AM
Axle Shaft...Question ARSpider2.0 Spider - 105 & 115 Series (1966-1994) 2 02-18-2005 11:35 AM
