Broken Shift Rod /105 - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 04-07-2019, 02:31 PM Thread Starter
MOZZAFIATO's Avatar
Greetings all wise ones,
While in the process of sorting out the gearbox on one of my Spider projects (typical gear crunching and difficulty engaging the gears prompted the project,) on the second turn loosening of the 4/3 shift rod bolt the darn thing severed in half. Why would this happen? Could it have been loose and perhaps bending the rod and throwing something out of alignment that was causing the original issues?
More importantly does anybody know where i would be able to find one?
MOZZAFIATO is offline
post #2 of 3 (permalink) Old 04-07-2019, 02:47 PM
kengta's Avatar
I likely have that rod here in Toronto. Let me know if you fail to find one closer to home. Now sure why that broke but there was likely a fatigue crack there that you work caused it it to fail completely.
Regards
Ken
[email protected]
Ken Geiger, Toronto
1965 GTA, RHD, Stradale
ex- 1965 GTA, RHD, Corsa, Trans/Am 66-72
1970 Giulia Super (CDN Spec)
1976 1600 GTj (Italian Spec)
2000 Catalina 320, Hull #765 Northern Dream
2001 BMW Z3 3.0i
kengta is online now
post #3 of 3 (permalink) Old 04-15-2019, 10:40 AM
kengta's Avatar
So Mozza what did you end up doing?
Ciao
Ken
Ken Geiger, Toronto
2001 BMW Z3 3.0i
Similar Threads
Shift Rod Detent Springs - '67 GTV mathcg Gearbox, Transaxle, Differential & Propshaft 2 03-18-2017 10:42 PM
Inner Tie Rod End Replacement rj7630 164 & 168 (1991-1995) 9 03-21-2014 05:02 PM
1994 ls crankshaft groove Luigim 164 & 168 (1991-1995) 14 01-01-2014 04:03 PM
Broken Throttle Rod trainkid4449 Spider - 105 & 115 Series (1966-1994) 4 02-10-2013 07:20 PM
How do I remove the gear shift rod budzinsk Gearbox, Transaxle, Differential & Propshaft 5 10-10-2008 01:59 PM
