Sorry if its been asked before but - Alfa Romeo Bulletin Board & Forums
post #1 of 7 (permalink) Old 05-15-2018, 12:00 PM Thread Starter
Alfanut1750's Avatar
How do you remove the brake disc covers on an Lsd rear axle. It looks like the whole shaft has to come out? I want to refurbish it so any links appreciated.
Thx
chris
Alfanut1750 is offline
post #2 of 7 (permalink) Old 05-16-2018, 02:34 AM
GTA R's Avatar
Thx
chris
Unfortunately that's the case, I've only ever fitted new ones after fitting new wheel bearings, BUT, looking at it again on the car, after removing the 4 bolts that hold the halfshaft assembly in, you may be able to slide the old one out and a new one in because of the cut-out in the back plate.
Steve
GTA R
1963 Giulia Ti Super Rep
GTA R is offline
post #3 of 7 (permalink) Old 05-16-2018, 04:25 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
Sorry, you'll need to remove the caliper, rotor and axle.
ossodiseppia is offline
post #4 of 7 (permalink) Old 06-16-2018, 07:41 AM
Here's a silly question...how do I know if I have a LSD in this 83 Spider?
Gmach is offline
post #5 of 7 (permalink) Old 06-16-2018, 08:36 AM
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
All Spiders had them since 1972...ish
If you can't explain it simply, you don't understand it well enough
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #6 of 7 (permalink) Old 06-16-2018, 09:05 AM
GTA R's Avatar
Standard on 2 ltr Spiders.
Easy to spot, the diff casing is different to non-lsd.
It has a triangle in the casting, see pic.
No triangle in non-lsd axles
GTA R
GTA R is offline
post #7 of 7 (permalink) Old 06-16-2018, 03:42 PM
Thanks....that's great.
So, can I put Bilstein W75 oil in it.
Local Italian car specialist suggested that was the correct oil for the diff.
Gmach is offline
