Dust cover on propeller shaft flange! - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 10-05-2017, 01:54 AM Thread Starter
Sketchl's Avatar
I recently noticed a `jingling' sound coming from my 2L diff on my 105 when cruising in gear, not under power.
On inspection, I noticed that the dust cover on the diff propeller shaft flange is loose and no doubt the culprit!
Question: How should the dust cover be secured to the shaft flange?
Thanks in advance
1966 Giulia Sprint GT Veloce - slightly modified!
Sketchl is online now
post #2 of 5 (permalink) Old 10-05-2017, 04:39 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
I believe it's a press fit.
ossodiseppia is online now
post #3 of 5 (permalink) Old 10-05-2017, 06:29 AM
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
Is #12 tight?
“If you can't explain it simply, you don't understand it well enough”
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #4 of 5 (permalink) Old 10-05-2017, 01:31 PM Thread Starter
Sketchl's Avatar
Thanks for the responses.
#12 is definately tight!
Ok, being press fit I’ll need to twist the dust cover on the flange to try and bind-it secure again....
Ciao
Sergio
post #5 of 5 (permalink) Old 10-05-2017, 01:34 PM
USTA BE AN AD-MIN
I probably mis-spoke. It appears to be part of the flange, so it would be either press fit or welded in some manor or fashion. If you tweak it, you run the risk of it scraping.
