Basic question - clutch in or clutch out - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 1 Post By ghnl
  • 1 Post By Alfajay
  • 1 Post By 60sRacer
post #1 of 6 (permalink) Old 07-10-2017, 05:53 PM Thread Starter
james2000's Avatar
Assuming you come to a stop at a red light (or similar) is it preferable for the clutch durability to keep the car in gear or let the clutch out in neutral? Never read any technical wisdom on this subject.
What do the gurus say?
Cheers, James
1970 GTV (owned since 1987)
1985 GTV2.5
james2000 is online now
post #2 of 6 (permalink) Old 07-10-2017, 06:07 PM
BB Janitor
ghnl's Avatar
Clutch out, transmission in neutral. Unless I am in a position where I might need to move quickly (say to avoid being rear ended for example).
Alfajay likes this.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #3 of 6 (permalink) Old 07-10-2017, 08:43 PM
I cringe when I let someone drive one of my Alfas and they sit at the light with the car in gear and the clutch down. I would have failed my driving licence test in England if I had done that.
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is offline
post #4 of 6 (permalink) Old 07-10-2017, 08:50 PM
Alfajay's Avatar
Originally Posted by alfaparticle View Post
I cringe when I let someone drive one of my Alfas and .....
You let other people drive your Alfas? You're a more patient man than I (which isn't saying a lot).
alfaparticle likes this.
'63 Guilia spider
Alfajay is offline
post #5 of 6 (permalink) Old 07-27-2017, 02:00 PM
At the least, idling with the clutch in loads the crankshaft axial bushing, causing extra wear. Cheap part that requires nearly total teardown to replace.
Robert
Anfanuts likes this.
60sRacer is offline
post #6 of 6 (permalink) Old 07-28-2017, 02:10 AM
GTA R's Avatar
Out of gear, in neutral. Keeping the clutch in, wears the clutch release bearing and the crank thrust washers,
Steve
GTA R
1963 Giulia Ti Super Rep
GTA R is offline
