What's this "nochiness" in 3rd gear? - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 07-02-2017, 05:50 PM Thread Starter
Sfizio's Avatar
I have read in these forums about a "nochiness" feeling when shifting. It's that crunchy, clicky, resistance I get when when trying to change gears. It get worse with aggressive driving. When I get into gear it's as if I've pushed a new key into an old lock. Happens in all gears a bit, except maybe fifth. First gear nochiness has been described in these forums and the solution seems to be drop into second before going up into first. As my mechanic says (and stop me if you've heard this one) they all do that. But lately, third gear has developed a very specific notch. With a gentle shift it's barely detectable. But with a little hard driving, I have to push to get that gear in place, more so than the others. Anyone know what causes this? Is it a problem or a feature? I don't yet know enough about transmissions to understand what is going on.
Sfizio is offline
post #2 of 8 (permalink) Old 07-02-2017, 06:10 PM
goats's Avatar
Check your slave cylinder and see how much throw you are getting. Should be a healthy 1/2 inch throw as. I recall. I think your clutch hydraulics are talking to you.....
goats is offline
post #3 of 8 (permalink) Old 07-02-2017, 06:13 PM Thread Starter
Sfizio's Avatar
Hadn't thought about that.
Sfizio is offline
post #4 of 8 (permalink) Old 07-02-2017, 06:31 PM
Gubi's Avatar
That's a good start. Also make sure your clutch pedal is level with the brake. If it's low and can be pulled up level your clutch pivot weld has failed.
If that all looks okay, I'd just try a fluid change with one of the recommended gear oils. It could be low.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is offline
post #5 of 8 (permalink) Old 07-27-2017, 01:58 PM
Also, update your TX lube to the appropriate Redline product. It makes quite a bit of difference in the quality of shifting.
Robert
60sRacer is offline
post #6 of 8 (permalink) Old 07-31-2017, 03:03 PM
Be sure you read the "First Gear Fix" thread. The one issue with idling in neutral is that as you push into first gear you will get that horrid crunch of a non-synchro mesh of just the first gear.
I still can't understand Alfa making the first gear different from all the others.
Robert
60sRacer is offline
post #7 of 8 (permalink) Old 08-01-2017, 03:42 AM Thread Starter
Sfizio's Avatar
Thanks all for the suggestions. All mechanicals checked out. I did change the fluid (and cleaned out a bit of muck at the bottom of the reservoir) prior to driving to Montreal and that made a noticeable difference.
Spending my kids' inheritance one mechanic at a time.
Sfizio is offline
post #8 of 8 (permalink) Old 08-01-2017, 04:55 AM
rogerspeed's Avatar
make sure the transmission output flange nut is tight, unfortunately to check you must remove the driveshaft
current:
84 Spider Veloce
ex:
rogerspeed is offline
