Detailed Step by Step Rebuild of 1972 5 Speed - Page 4 - Alfa Romeo Bulletin Board & Forums
 11Likes
post #46 of 73 (permalink) Old 05-04-2016, 07:04 AM
Richard Jemison
Alfar7's Avatar
Tripods
Goats is correct
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is online now
post #47 of 73 (permalink) Old 05-06-2016, 06:43 PM
Jim G's Avatar
Originally Posted by Alfar7 View Post
Goats is correct
How can one be different if all three carry the same part number.
Also the page from and original spider shop manual.
Jim G is offline
post #48 of 73 (permalink) Old 05-06-2016, 09:50 PM
goats's Avatar
It indeed says that -- all synch hubs are identical. I note a 1985 date on that manual -- I wonder if earlier models might have had a difference? I can say that I am pretty sure that on my 74 trans, original to the car, the 5th gear tripod (synch sleeve hubs as noted) was slightly longer on the ?outboard? 3 legs than the other 15 legs (Im counting a leg as the distance from the center of the hub to the outer edge of the leg). By about 10 to 15 thou if I recall. And as I said, the metrology was difficult.
Don't want to argue about it tho, and I am not taking the trans out of the car to prove myself right or wrong. Its not that important to me! Rock on!
PS after more than a year and maybe 4 K miles, that trans is silky smooth and crisp all at the same time! What a difference a quality job on the gearbox makes. I HOPE I can repeat that outcome with this spider trans.
velocedoc and Alfaboutvegas like this.
goats is online now
post #49 of 73 (permalink) Old 05-10-2016, 08:58 AM
Alfaboutvegas's Avatar
Wink SMOOOTH
May I comment,
That gear box IS SILKY SMOOTH!, that "Goats" is mentioning.
No reason to pull that one to prove anything.
"No chance, no destiny, no fate can circumvent, change or control the firm resolve of a determined soul"
73 Spider
80 BMW e21(Sold, gone to Houston)
79 Spider (sold)
78 Spider (sold, gone to U K)
Greg
Alfaboutvegas is offline
post #50 of 73 (permalink) Old 05-30-2016, 10:50 PM
Ranz's Avatar
Orientation of speedo drive?
Hello people, I removed my speedo drive without noticing the oil hole, and whether the oil hole should be 'up' or down on installation, acting as a fill hole or drain hole....
Which is correct, please?
Ranz is offline
post #51 of 73 (permalink) Old 06-01-2016, 01:22 AM Thread Starter
Have some pics posted on page 1; not sure if that will help.
72 GTV; 66 Fairlane GT convt, 428, 4 sp; 68 GTO Convt, owner built 455 and TH400; 71 Javelin road race project, owner built 401, T10
bulletpruf is offline
post #52 of 73 (permalink) Old 06-01-2016, 01:56 AM
Ranz's Avatar
Thank you, Bulletpruf, but not really, unless you remember which way up the hole you can see in your photo in post 6 goes...
If you didn't take note at the time yourself, then I suppose you need the same answer as I do!
There seems to be no other indicator on the drive unit or the housing as to which is the correct orientation.
EDIT: there is an oil galley I hadn't spotted at the 11 o'clock position which aligns with the hole. Answer, therefore, is 'up'.
Ranz is offline
post #53 of 73 (permalink) Old 06-01-2016, 04:09 AM Thread Starter
Sorry, I really don't recall. Hopefully someone will chime in.
Scott
post #54 of 73 (permalink) Old 06-01-2016, 04:11 AM Thread Starter
Early vs. Late Transmission?
All -
Can someone please educate me on how to tell the difference between an early and a late transmission? I have two -- the one that's the focus of this thread, which came out of my 1972 GT Junior 1300 (assume it's original, but not positive) and one that came with a 1972 or 1973 2L engine that I bought.
There are small differences between the two, including bearings, and now that I'm about to order bearings, I need to make sure I'm ordering the right ones.
Thanks!
Scott
post #55 of 73 (permalink) Old 06-07-2016, 01:01 PM Thread Starter
post #56 of 73 (permalink) Old 06-07-2016, 01:04 PM Thread Starter
post #57 of 73 (permalink) Old 06-07-2016, 01:06 PM Thread Starter
post #58 of 73 (permalink) Old 06-07-2016, 01:07 PM Thread Starter
post #59 of 73 (permalink) Old 06-07-2016, 01:08 PM Thread Starter
post #60 of 73 (permalink) Old 06-07-2016, 09:23 PM Thread Starter
Now that I have the pictures posted, I need to go back and upload details. May take a while, but I will get to it.
Scott
