URGENT HELP NEEDED Transmission Problem! - Page 3 - Alfa Romeo Bulletin Board & Forums
post #31 of 52 (permalink) Old 05-10-2007, 09:39 AM Thread Starter
ddouglas77's Avatar
Send a message via MSN to ddouglas77
Originally Posted by pillowmeto View Post
If you chipped any gears, I have extras around. you can have one for the price of shipping, but you may need to replace the bushing in them.
-Matt
ps. ive got a few other parts around as well
This is why the Alfabb is so **** great-I highly appreciate the offer pillowmeto-I'll let you know-my hands aren't greasy yet-I just got done unloading a 6 ton jack out of my dad's van along with 4 jackstands, time to make this Alfa reach for the stars
[SIGPIC][/SIGPIC]1990 Alfa Camaro Spider Super Sport Special American/Italian Edition. Pizza Burner with Pizzaz!
1974 Chevrolet Camaro
ddouglas77 is offline
post #32 of 52 (permalink) Old 05-17-2007, 11:33 AM
crashmctavish's Avatar
Finished yet?
crashmctavish is offline
post #33 of 52 (permalink) Old 05-17-2007, 03:34 PM Thread Starter
ddouglas77's Avatar
Originally Posted by crashmctavish View Post
Finished yet?
It's still in the car, I've had job interview after interview after interview-using my Dad's work van for transportation in exchange of servicing his drum brakes, water pump, exhaust sytem and power steering pump. I may have a job and you may be right-somewhat-of what I'll end up spending...with all new syncros and rings, bearings, seals, bushings and having ALL the gears lightened and new dog bones installed: $2,170 USD. That is if I get the job I want, otherwise, 1 new syncro and 3 rings and front and rear seal will be the limit.
post #34 of 52 (permalink) Old 05-22-2007, 09:53 PM
So have you finished it yet!
post #35 of 52 (permalink) Old 05-24-2007, 08:17 AM Thread Starter
ddouglas77's Avatar
Depends on your definition of finished...
The black spot in front of the tranny is not oil, black epoxy paint my boy spilt. Oil came out clear (Mobil One Synthetic).
Take a good look at the tranny mount!
post #36 of 52 (permalink) Old 05-24-2007, 08:27 AM
lowmileage's Avatar
Nice BFH you have there
Loud pipes save lives.
1973 GTV - bought 3/06, intend to keep forever
1969 GTV, #AR1530021 - sold 10/72, guess didn't intend to keep forever
Current project: '69 Corvette bought in '73, DD '73 - '80, in storage 1989-2002, now apart
lowmileage is offline
post #37 of 52 (permalink) Old 05-24-2007, 08:51 AM Thread Starter
ddouglas77's Avatar
Huh, what is bfh?
post #38 of 52 (permalink) Old 05-24-2007, 08:59 AM
lowmileage's Avatar
Someone please
post #39 of 52 (permalink) Old 05-24-2007, 09:01 AM Thread Starter
ddouglas77's Avatar
Someone please
big f***ing Hammer????
post #40 of 52 (permalink) Old 05-24-2007, 09:06 AM
It looks very clean as If it has been out recently? Mobil 1 cannot be the right oil. Remove the guibo & yoke 1st. Dont lose the 3 beans on the shift rod interlock. All details are within this forum. Regards
post #41 of 52 (permalink) Old 05-24-2007, 09:20 AM Thread Starter
ddouglas77's Avatar
Yup, Mobil One is not the right factory oil, It is the best oil
post #42 of 52 (permalink) Old 05-26-2007, 07:24 AM Thread Starter
ddouglas77's Avatar
Will I need gear pullers to get the gears off the shaft? I got my first gear off last night, but 2nd gear doesn't want to come off, there is a shim on the shaft that doesn't seem to want to budge, am I missing an easy trick here?
post #43 of 52 (permalink) Old 05-26-2007, 09:13 AM
Yes you will.
post #44 of 52 (permalink) Old 05-30-2007, 06:04 AM
I use a press and metal plates to remove all gears but 3rd, which i use a puller on the tunion, then remove the key ways, then the gear. That helps prevent sratching the bushing on the keyways.
83 Spider Veloce
pillowmeto is offline
post #45 of 52 (permalink) Old 05-30-2007, 06:34 AM Thread Starter
ddouglas77's Avatar
First I used a gear puller, then I used a brake caliper piston compressor tool. The syncro for 5th and reverse was in beautiful condition, 3rd to 4th had a little wear on the 3rd side, so I traded that one with 5th to R, with "bad" side facing rear. First and second needs replacement. Dog rings look alright, some better than others, I will gently file those bad looking ones into shape...Should I have 1,2 and 3 gear lightened? I was thinking it may be more power producing to do 1,2 and reverse as reverse is constantly spinning on the shaft and is much bigger than 3rd gear, what do you guys think?
