Bronze gear bushing clearance - Page 5 - Alfa Romeo Bulletin Board & Forums
 8Likes
post #61 of 70 (permalink) Old 02-04-2018, 02:32 PM Thread Starter
goats's Avatar
Here is what happens if first gear is too tight. I set it to about 1 to 1.5 thou— it rotated cleanly with oil and I thought I was good to go. Lesson — tight tolerances can be TOO TIGHT!!!
Result— had to pull trans out, crack it open and now fighting with mainshaft and tripod placement.
goats is online now
post #62 of 70 (permalink) Old 03-08-2019, 08:38 PM
1750GT's Avatar
I am going through a transmission rebuild and want to check the radial clearances between the gear bushings and the mainshaft. It seems the most accepted limits area the following;
1st - .0049"-.0067"
2nd -.0037"-.0055"
3rd - .0026 -.0042"
Are the limits above supposed to be radial or diametral clearances?
When I measure my gears, I get the following results;
1st - bushing I.D = 1.3785"
shaft O.D. = 1.3725"
clearance = 0.0060"
2nd- bushing I.D = 1.3795"
shaft O.D. = 1.3735"
clearance = 0.0060"
3rd - bushing I.D = 1.3780"
shaft O.D. = 1.3755"
clearance = 0.0025"
cheers
1750GT is offline
post #63 of 70 (permalink) Old 03-08-2019, 08:58 PM Thread Starter
goats's Avatar
Diameter. Personally I would not use anything more than 3.5 thou and nothing less than 1.5 Ish. But that’s just my view. Don’t make first less than 1.5!!!
goats is online now
post #64 of 70 (permalink) Old 03-08-2019, 10:30 PM
Norseman50's Avatar
Bob,
Did you secure the dimpled bronze bush to the gear with any Loctite when you pressed it into place (prior to honing it out)?
Edward
'88 Quad - "Claudia"
Norseman50 is offline
post #65 of 70 (permalink) Old 03-08-2019, 11:11 PM Thread Starter
goats's Avatar
I really don’t remember. If I did it was locktite green but I truly don’t recall for certain — Richard says nonloctite as it can expand —
Bob
goats is online now
post #66 of 70 (permalink) Old 03-09-2019, 05:47 AM
1750GT's Avatar
Originally Posted by Top Down View Post
I have now seen an original Alfa Romeo spec sheet from 1989 covering these tolerances. They state:
1st .008 - 0.012
2nd and 3rd .005 - .008
So if its good enough for original build its good enough for me.
What document is showing these as wear limits? I ask because these limits would indicate that my gears would be good to go!
Whereas the wear limits in post #62 tells me that I'm only 7/10 of a thou under at the upper limit on 1st , 1/2 thou over on 2nd and 1/2 thou under on 3rd.
From the few accounts I've read on this thread.....reaming/honing new bushings might be an issue and unecessary in my case.
1750GT is offline
post #67 of 70 (permalink) Old 03-09-2019, 07:15 AM Thread Starter
goats's Avatar
Well there is that consideration too. It is a true hassle to replace the bushings. I did it both times because I wanted the trans as perfect as possible, and I wanted the experience.
I agree that if you are out of spec it’s by a hair at most. A lot of this is feel too — if your wear remains concentric and truly non offset, I’d probably ( at this stage in my life) leavecem alone. If you are not racing etc I would be happy enough I suppose just cleaning and reassembling as-is. Really a judgement /time/ resources /hassle factor call.
I would NOT criticize or suggest otherwise if you were to leave as is. Pretty gray area unlike an oil pump that’s out of tolerance!!
goats is online now
post #68 of 70 (permalink) Old 03-09-2019, 10:14 AM
Top Down's Avatar
Now that might not be so easy to find! At the time I would have been scouring the internet for information, once recovered and used I didnt keep a reference, my bad. I'll have trawl through some folders to see if I did keep it.
PS. I do recall the source now. It was a photo of a workshop manual which I was sent by Ian Ellis who is a well known Alfa specialist here in the UK. I have found my email to him, thanking him for the information, but not the email to me.
Daily drive is a Giulia 2.0 MA, wife drives a 939 Spider in the summer and a 1.6TS 147 in the winter. For special sunny days we have a S2 Spider Junior in the garage.
Top Down is offline
post #69 of 70 (permalink) Old 03-09-2019, 02:25 PM
Norseman50's Avatar
1st - .0049"-.0067"
2nd -.0037"-.0055"
3rd - .0026 -.0042"
Diametrical.
clearance = 0.0060"
clearance = 0.0060"
clearance = 0.0025"
cheers
At the present time, after rebuilding a couple of Alfa Romeo 5-speeds (in which I replaced these gear bushes and struggled to find a competent enough machinist to broach them out to 0.002" over the mating shaft diameters), and having discussed this clearance question with a Mechanical Engineer who designed transmissions for Chrysler Corp. during the 70's and '80's (and now owns a European Transmission repair shop in Seattle), I have come to the conclusion that a clearance in the 0.002" to 0.006" range for any of these gears is suitable, and I would even reuse one with a 0.007" clearance before going to the trouble of pressing out an old, and then pressing in and honing out a new dimpled bronze bushing.
However, if I owned (or had access to) a top quality lathe, I'd modify a set of 10" Full Grip Tongue & Groove Aluminum Lathe Soft Jaws (4" HT, 10" Pie Diameter) that would allow me to secure these gears with negligible run-out and then I'd be able to broach out new internal bushes to ten-thousandths tolerances.
Bottom line is, I'd just re-use your gears with your present clearances, and not fuss with replacing the internal bushings.
Good luck,
Edward
post #70 of 70 (permalink) Old 03-09-2019, 09:02 PM
1750GT's Avatar
Originally Posted by Norseman50 View Post
Diametrical....... I have come to the conclusion that a clearance in the 0.002" to 0.006" range for any of these gears is suitable, and I would even reuse one with a 0.007" clearance before going to the trouble of pressing out an old, and then pressing in and honing out a new dimpled bronze bushing.Bottom line is, I'd just re-use your gears with your present clearances, and not fuss with replacing the internal bushings.
Good luck,
Yeah that's what I'm going to do for now. It's going to be a little loose I'm sure.....but I need to get the car completed by Spring this year! So if the tranny turns out to be too problematic or noisy...I'll replace everything on the next rebuild...bearings & bushings.
1750GT is offline
