GTA-style half shafts - Alfa Romeo Bulletin Board & Forums
post #1 of 36 (permalink) Old 04-27-2006, 12:16 AM Thread Starter
Alex's Avatar
I recently bought a 2-litre Berlina LSD with a 43/10 CWP after spending far too long trying to find the non-LSD 1750 Berlina version, because of the smaller diameter of the latter version's half-shafts (then fitting another type of LSD). I've noticed that in the parts manual there is another variety of half-shaft for the GTA which has a 'scalloped' output flange where it butts against the back of the rear brake disk, part # 105.14.17.300.00 . Anyway, I've also read that some of these half-shafts were 'gun-drilled' and I wonder if someone could explain what that means (I'm thinking hollow along the length), whether the shafts are just as strong when used in conjunction with a non-locked rear end, and whether anyone has attempted to modify standard half-shafts in this manner?
Alex.
Alex is offline
post #2 of 36 (permalink) Old 04-27-2006, 12:53 PM
vintage prep's Avatar
Yes they are drilled along there length. The fact is, the metal in the center if any solid rod does little to add strength, mostly it adds weight, which you would'nt want in your racing GTA. Hence the drilled center. Same idea with modern racing tubular sway bars.
I was wrong once before,
Paul Van Der Linden
Currently: 70 Giulia Ti 2.0L
Formerly:
(1) 58 spider
(2) 67 duetto's
(4) 67 super's
(2) 67 gtv's
(1) 70 gtam
(2) 74 gtv's
(1) 78 spider
(1) 82 spider
vintage prep is offline
post #3 of 36 (permalink) Old 05-18-2006, 09:23 AM
GTA Halfshafts
The GTA shafts had a different number of splines than production models. Not interchangable. For SCCA racing we ended up using 2 litre assemblies with tightened up LS for reliability and frugality after several GTA type broke. 70ep
70ep is online now
post #4 of 36 (permalink) Old 06-21-2006, 09:10 AM
Max Banks's Avatar
yep the only halfashaft we have ever seen broken is a GTA course spline hollow one! We use 1300/1750 halfshafts always to save weight and have never broken one.
[COLOR=Blue]
[/COLOR]
1966 2.0 Sprint GT race car, 1967 T/S GTA Replica, 1965 FIA App.K 1600 GTA, 1965 1600 GTA Stradale RHD, 1965 1600 GTA Stradale LHD, 1966 1600 Giulia GTC, 1991 S4 Spider, 1967 1600 Duetto, 1999 2.0 916GTV (soon to be sold!) and now replaced with 2002 3.0 V6 24v 916 GTV
Max Banks is offline
post #5 of 36 (permalink) Old 06-21-2006, 01:45 PM Thread Starter
Alex's Avatar
So with my 2-litre Berlina LSD, I'm definitely stuck with the larger diameter half-shafts?
Alex is offline
post #6 of 36 (permalink) Old 06-21-2006, 04:16 PM
PSk
Originally Posted by Alex
... after spending far too long trying to find the non-LSD 1750 Berlina version ...
Alex.
Would that be the same as a 1750GTV? ... because I have 2 non-LSD rear axles for my car.
'71 1750 Series 2 GTV:
PSk is offline
post #7 of 36 (permalink) Old 06-22-2006, 07:59 AM
Max Banks's Avatar
yep Alex you are stuck!
PSK - no its not 1750 GTV is 4.1 ratio, not 4.3 (unfortunately)
[COLOR=Blue]
[/COLOR]
post #8 of 36 (permalink) Old 06-22-2006, 09:24 AM Thread Starter
Alex's Avatar
Hmph, time to find someone with a huge lathe to turn down the shafts (don't worry, that was said in jest)
Alex is offline
post #9 of 36 (permalink) Old 06-22-2006, 05:09 PM
PSk
Gee so the halfshafts are different for the different ratios? ... bugger and strange (and why?).
PSk is offline
post #10 of 36 (permalink) Old 06-22-2006, 09:23 PM
Alleggerita's Avatar
1300, 1600, 1750 have one type of half shaft, 2000 w/ and w/o LSD has another, heavier ones. Both types have fine spline. GTA with LSD's for the most part had heavy spline ones that are heavier than the 1300-1750 shafts but less beefy than the 2000 ones. Some of the GTA ones were gun drilled for lightness (referring to the process of how you drill a gun barrel).
BTW, there is a factory optional LSD unit to fit with the 1300-1750 light spline halfshafts but that is relatively rare. Consequently, some people adapt the later 2000 LSD's for use in the 1300-1750 rear end. They often use the lighter 1300-1750 halfshafts to shed weight (this involves some machining - I believe there is a thread on this). Personally I prefer use the entire 2000 assembly after having seen a few halfshafts letting go on hot 1750's.
So halfshaft don't depend on ratio but on type of rear end and type of LSD fitted.
Alleggerita is offline
post #11 of 36 (permalink) Old 06-22-2006, 09:53 PM
PSk
Okay I'm trying to work out what Alex originally wanted .
I now think it was a non-LSD 43/10 CWP for a 1750 Belina, or whole rear axle.
Now I have a 2 x 4.1 ratio non-LSD rear axles (one with teeth off the pinion, hence why I have 2), and Alex has a 43/10 LSD rear axle. Can you not change remove the 4.3 crown wheel (from the LSD diff) and bolt it on the non-LSD 4.1 diff centre and use the 4.3 pinion in one of my type rear axles? Thus as the diff centre is still designed for the 1750 it will have the right size half shaft requirement ... and bam you have a non-LSD 43/10 1750 rear axle!!!
My point is it is the differential centre that dictates the half shaft requirements not the ratio, surely the crown wheels are interchangeable ... surely Alfa Romeo is not that stupid to make them unique, surely!
I've yet to open an Alfa Romeo rear axle, but done plenty of Ford Escort ones and I used to change diff ratios all the time by changing the crown wheel and keeping the expensive gear type LSD centre ... I had a set of diff noses (actually 4 of them) where the pinions live on these axles, all set up, etc. ... for my track car.
PSk is offline
post #12 of 36 (permalink) Old 06-22-2006, 10:14 PM
Sorry Pete, Alfa 2000 crown & pinions are different from the 1300-1750 ones. In fact the different ratios on the 2000 are available with either an 8-bolt or 10-bolt crown wheel. US 2000's are usually 8-bolt. However, the only way to find out for sure is to open it up. Been there, done that when I changed ratio on a 2000 diff.
post #13 of 36 (permalink) Old 06-22-2006, 10:46 PM
PSk
Bloody heck ... Alfa Romeo are crazy
Now it all makes sense anyway .
PSk is offline
post #14 of 36 (permalink) Old 04-29-2007, 04:47 AM Thread Starter
Alex's Avatar
Brief revival of this thread ...
Let's just say that I found a local company that is able to drill out my (2L LSD) half-shafts for a really economical price . I've got some questions:
1. Does anyone know the bore size/depth of these lightened shafts?
2. Would the hole at the outboard end of the shaft need plugging?
3. This company can deep-bore to a tolerance of 0.001" drill wander per 1" of bore depth - would any slight inconsistency in the bore cause balance issues?
4. Max mentions that the only type of half-shaft he's broken is the coarse spline hollow type. Is this because of the splines or the hollow shaft? My intuition tells me that a tube is actually more resistant to torsional stresses than a solid shaft?
5. Is this overkill for a road car or does 'every little help'?
Just wondering on a quiet Sunday ...
Alex.
Alex is offline
post #15 of 36 (permalink) Old 04-29-2007, 06:24 AM
GTA Halfshafts
Can't help on # 1,2,or3 but I know where every GTA shaft broke - about 3'' from the hub and the shaft was solid at that point. 70ep
70ep is online now
