GTA-style half shafts - Page 3 - Alfa Romeo Bulletin Board & Forums
post #31 of 36 (permalink) Old 07-14-2015, 06:58 PM
Richard Jemison
Alfar7's Avatar
Axle
Simple.
Have a 2 liter axle resplined to the smaller 105 spline size.
Simple as well, convert to a 2 liter LSD Diff.
I build 105 sized LSD units by machining 2 liter LSD carriers to match bearing & ring gear positions of the 105 smaller unit. Then welding up the splined ends of the 105 axles and re-splining to fit the larger 2 liter drive splines which fit the LSDs units.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #32 of 36 (permalink) Old 07-14-2015, 09:40 PM
Sure doesn't seem like that would leave a lot of meat in between the ID of the carrier bearings and the OD of the axle splines---
Greg
bearbvd is offline
post #33 of 36 (permalink) Old 07-15-2015, 05:47 AM
Richard Jemison
Alfar7's Avatar
axles
The 2 liter axles are much larger OD than those in the 105 series cars.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #34 of 36 (permalink) Old 07-15-2015, 08:28 AM
Precisely. And the ID of the inner race of the carrier bearings for the 2 liter axles is also much larger than it is in the earlier axles. hence my comment. Boring the carrier from an early axle to accept the late axle shafts would tend to leave the bearing seats on the carrier on the thin side.
bearbvd is offline
post #35 of 36 (permalink) Old 09-07-2017, 08:52 PM
Is any one making reproduction course 15 spline axles? for GTAs
Steve105 is offline
post #36 of 36 (permalink) Old 09-08-2017, 01:13 AM
PSk
http://www.alfabb.com/bb/forums/gta-...15-spline.html
'71 1750 Series 2 GTV:
PSk is offline
