tranny for 1600 bellhousing? - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 05-23-2012, 03:13 PM Thread Starter
lotuseleven's Avatar
Could someone please identify this transmission, and tell me if it can be mounted to a 1600 bellhousing? I'm pretty sure that it was sourced by the PO to install in a 73 spider, but it doesn't look like I expected. want to use it with a cable clutch if it will work in the 1600 bellhousing.
thanks for all help,
Stan
Stan Swanson, Eerie Erie, Colorado, '67 GTV (daily driver), '71 GTV (Kyle's), '91 164 (snow car), '56 Lotus 11(gone to Oz), '59 Cadillac M+M Hearse, '74 MGB
lotuseleven is online now
post #2 of 6 (permalink) Old 05-23-2012, 03:16 PM Thread Starter
This is what I was expecting to see, and have seen threads about adapting this transmission for the early bellhousing.
post #3 of 6 (permalink) Old 05-23-2012, 04:22 PM
Richard Jemison
Alfar7's Avatar
115 series in 101 bell housing
Only needs correct oil seal with smaller center to fit. I keep them in stock.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #4 of 6 (permalink) Old 05-23-2012, 05:15 PM
And a plate to cover the shift rod opening. With a bracket for the reverse switch, if you want a reverse light. Otherwise there will be an oil leak because the later short shift rods do not have "0" rings to seal them.
hotlegs32 is online now
post #5 of 6 (permalink) Old 05-23-2012, 05:25 PM Thread Starter
Karen, does the cover plate need to be welded or sealed in the opening?
post #6 of 6 (permalink) Old 05-23-2012, 06:48 PM
Just sealed. I have never welded one in and have had no problems.
But without a reverse switch as they were for early Spiders.
