selling my t5 kit - Page 7 - Alfa Romeo Bulletin Board & Forums
post #91 of 97 (permalink) Old 12-19-2011, 02:31 PM
alfavulcan's Avatar
to clarify the tunnel issue, i did not cut my trans tunnel for the shifter location, the wider flat section top driver's side interfered w/tunnel. the 115 chassis has the tunnel offset about an inch to the passenger side as the motor is canted and the crank centerline is not centered in the car. i am using a 3.0 v6 mounted nearly centerline in the chassis, just slightly to the right. that being the case it just made clearance issues worse. with a 4 cyl with trans in original location, may or may not be an issue.
87 graduate, 81 gtv6, 91 164s, 73 berlina 79 Mille miglia GONE: 76 alfetta gt, 74 berlina, 85 gtv6, 79 spider
alfavulcan is offline
post #92 of 97 (permalink) Old 12-19-2011, 02:38 PM
alfavulcan's Avatar
p.s. i totally agree on DON'T paint the tranny, except maybe a silver. i prefer just cleaned very well. i checked out several before pulling the one i bought, none were painted, most looked like they had never been pulled.
post #93 of 97 (permalink) Old 12-19-2011, 06:03 PM
mongollion's Avatar
I didn't realize you were using a V6. I'm still not afraid of cutting the tunnel, but if it ends up that I don't have to, so much the better. And natural aluminum is much nicer to look at, even if its under the car. To answer an earlier post, I really don't care if the modification is reversible or not since I will have the car until it falls apart then I'll buy another one and swap out the modifications that I have done and pass that one on to my son.
mongollion is offline
post #94 of 97 (permalink) Old 12-19-2011, 07:51 PM
alfavulcan's Avatar
its quite possible some careful sheetmetal contouring [ with a big ole hammer] could get any clearance needed, mine was too tight top left because of being shifted a little to the left
post #95 of 97 (permalink) Old 07-23-2012, 09:42 PM Thread Starter
to all those looking at my t5 tranny kit, plase e-mail me at [email protected] to many pm's to get back to. i re-designed the interface between the rear axle and the d/shaft. thats why the late reply..
anyone can buy a Porsche, only Drivers drive a Alfa Romeo
bianchi1 is offline
post #96 of 97 (permalink) Old 05-02-2014, 07:23 PM
Hans-Peter's Avatar
T5 update
T5 is in car and after one short drive seems pretty good, easy to change gear with strong syncros , change feels bit agricultural but so what, mustang box with chev S10 shifter, I have a quick shifter kit on it which makes the throws about the same as standard Alfa, .92 fifth should work well for me on track and its a very easy gearchange but probably not so useful on the road, it will allow me to change rear from 4.30 to 4.10 though.
Hans-Peter is offline
post #97 of 97 (permalink) Old 06-11-2018, 09:15 AM
kpc655's Avatar
I know it's an old thread - Bianchi1 do you still make / sell these?
kpc655 is online now
