Compression went South - Alfa Romeo Bulletin Board & Forums
 1Likes
post #1 of 28 (permalink) Old 08-20-2019, 05:23 AM Thread Starter
Freshly rebuilt 2L spider motor, was running good about 10 hours, getting the Webers and valve clearances adjusted. Fired her up yesterday and while warming up I heard a few clunks that did not sound at all normal. Checked valve train, appears ok, 5 psi compression on cyl. #3. 160 on the rest. #3 piston is moving up and down. Engine builder is old, maybe has lost touch (self)
It appears something catastrophic happened, any ideas?
930cabman is offline
post #2 of 28 (permalink) Old 08-20-2019, 06:54 AM
classicalfas's Avatar
I would remove the cam cover and cams and look under the followers first. See if everything looks in place.
horsewidower likes this.
1966 GTA replica, 1967 Duetto, 1987 Quadrifoglio
1972, 1973, 1974 Montreal
classicalfas is offline
post #3 of 28 (permalink) Old 08-20-2019, 06:59 AM
Richard Jemison
Alfar7's Avatar
Like a adjusting shim not seated on the valve, holding it open
Bring # 3 to tdc so valves "should be closed. Blow air through the spark plug hole. Side that air escapes through is the cam you need to remove and check.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #4 of 28 (permalink) Old 08-20-2019, 07:31 AM Thread Starter
Clearance at intake #3 is .015, exhaust .020
post #5 of 28 (permalink) Old 08-20-2019, 07:50 AM
Richard Jemison
Alfar7's Avatar
Still do the air test.
You could have bent a valve turning the cams without the two being timed together..
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #6 of 28 (permalink) Old 08-20-2019, 08:35 AM
Borrow or rent a borescope and take a look down the spark plug hole, look for kiss marks or dings from the valves on the piston to rule out a bent valve. My guess it’s a top end issue.
post #7 of 28 (permalink) Old 08-20-2019, 10:10 AM
Alfajay's Avatar
Agree. If piston #3 is still going up and down, then there isn't much else it could be. It might be a head gasket issue, but those clunks 930cabman heard suggests valve damage.
Alfajay is offline
post #8 of 28 (permalink) Old 08-20-2019, 10:14 AM
You can do a leak down test too.
post #9 of 28 (permalink) Old 08-20-2019, 10:29 AM
genericwood's Avatar
A bent valves would likely lead to excessive clearance. Could be a broken piston?
Erik
'66 GTV racecar, '71 Spider racecar, '74 GTV street car, '71 GTV project
genericwood is offline
post #10 of 28 (permalink) Old 08-20-2019, 10:51 AM Thread Starter
Richard nailed it again.
I shot some compressed air into cyl #3 (intake valve clearance .014, exhaust .020) and sure enough air was escaping from the venturi at cyl #3.
Not sure how this could have happened, but it looks like the head will be coming off, hopefully its in the top end.
post #11 of 28 (permalink) Old 08-20-2019, 05:27 PM Thread Starter
Pulled the cyl head off, a small metallic something found it's way into the combustion chamber. The top of the piston, underside of the head and valves are peppered with small dents. Generally I am very careful when the spark plugs are removed or when the carbs are off to make sure this does not occur. Hopefully the bottom end is ok.
Heading off to my local machine shop tomorrow to replace the damaged valves.
post #12 of 28 (permalink) Old 08-20-2019, 06:13 PM
Also have to be careful when the carbs are on but the cleaner is off. I have seen nuts and washers make there way past the throttle plates.
Erik
post #13 of 28 (permalink) Old 08-20-2019, 07:03 PM
Been there and done that.
https://www.alfabb.com/bb/forums/eng...n-chamber.html
2011 Jaguar XKR
alfaparticle is offline
post #14 of 28 (permalink) Old 08-20-2019, 07:47 PM
A good machine shop can work wonders. Hope everything gets fixed and back together. I'm guessing your rings are OK.
180OUT is offline
post #15 of 28 (permalink) Old 08-21-2019, 05:35 AM
Look at the before and after pictures in the link above. I did not have to pull the engine which was as strong as ever when I put the head back on. I only needed help to replace a damaged valve seat.
2011 Jaguar XKR
