Troubleshooting Oil Pressure gauge/sender problem - Alfa Romeo Bulletin Board & Forums
post #1 of 10 (permalink) Old 08-19-2019, 08:29 PM Thread Starter
Question Troubleshooting Oil Pressure gauge/sender problem
My 67 GTV with the original 1600 cc engine is having a problem with no oil pressure reading on the Oil pressure gauge. I thought that it might be the sender which I replaced with a brand new one which is fitted on the block under the carburetors. I still don't get any reading on the gauge. I'm trying to determine whether the problem is with the gauge, the wiring, or something else that I'm not aware of. Hopefully it's not something worse like, there is no oil pressure. Any help with the process of closing in on the problem would be greatly appreciated.
Oddly, the official Alfa "Spare Parts Catalog" doesn't show the sender under the carburetors but shows pictures of it being located on the oil filter housing.
808Alfa is offline
post #2 of 10 (permalink) Old 08-19-2019, 11:21 PM
Rosenmöller's Avatar
You probably need a sender for veglia 1. series. You can test the sending unit as follows:
without connecting the control line, the instrument will show full scale; when the sending unit is connected, the pointer goes 2 mm below zero; if the control line is connected to ground then the pointer goes to zero.
There are a lot of bad and non working units on the market now.
Salutations from the Baltic sea
Bernhard
Rosenmöller is offline
post #3 of 10 (permalink) Old 08-20-2019, 12:53 AM Thread Starter
Bernard, thank you for your reply. My gauges are Veglia gauges. I ordered what was in the catalog (Centerline or Spruell; I can't remember where I ordered it from). I don't recall the catalog specifying the type of gauges. I will follow your instructions and will report the results. Thank you.
808Alfa is offline
post #4 of 10 (permalink) Old 08-20-2019, 12:58 AM
centerline specifies:
https://www.centerlinealfa.com/catal...er-gauge-early
and you might as well look here:
https://www.alfabb.com/bb/forums/spi...html#post38665
Bernhard
post #5 of 10 (permalink) Old 08-20-2019, 07:04 AM
Richard Jemison
Alfar7's Avatar
Checking the gauge
If you ground the wire to the sender, the gauge should go to the Max reading.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #6 of 10 (permalink) Old 08-20-2019, 08:50 AM
That is for the later type gauges. The earlier ones work the opposite way.
2011 Jaguar XKR
alfaparticle is offline
post #7 of 10 (permalink) Old 08-20-2019, 09:57 AM
this is exactly what I wrote in post #2
Bernhard
post #8 of 10 (permalink) Old 08-25-2019, 02:33 AM Thread Starter
Red face Problem resolved
Thank you all for your responses. After checking several things I got under the dash and pulled out the gauge through the front of the dash but kept the wiring intact. Tested the oil pressure gauge and learned that wasn't the problem but did notice that there was a short black wire that came loose. I wasn't sure where it was dislodged from but quickly figured it out. Voila, problem solved. Oil pressure gauge is operating fine now.
808Alfa is offline
post #9 of 10 (permalink) Old 08-25-2019, 11:38 PM
Alfa's are infamous for loose grounds, especially behind the dash (where you will never see it).
Robert
60sRacer is offline
post #10 of 10 (permalink) Old 09-08-2019, 11:48 AM
I've got a 60 sprint (+ve ground)with a 105 series 1600. The temp gauge doesn't move unless I ground it at the sensor then full deflection. I'm sure the sensor is good. I wonder if it's a ground issue too, or do the giulietta gauge and later 105 gauges use different sending units. Anyone?
John
johnnyd is offline
