cylinders 1 & 2 not happy, good spark & compression - Alfa Romeo Bulletin Board & Forums
 4Likes
post #1 of 17 (permalink) Old 06-16-2019, 05:12 PM Thread Starter
Hey All,
Happy Father's Day!
Challenging problem here. First, '74 Spider 2000 Veloce w/Weber carbs. I've just replaced most of the fuel lines, tank filter, new fuel pump, and tank. All seem pretty good. This issue started just before I changed all the above out, but thought it was related to a torn fuel line (since replaced).
Other details: Fuel is getting to the webers, spark is good, compression is 150-160 across the board.
The car is waaay down on power. When idling, and the spark plug wires are removed from either cylinder #1 or #2 the engine is not impacted (no change in idle). Cylinder 3 & 4 nearly stop the motor when the wire is removed. So, cylinders 1 & 2 are not making any power and are fed by the same DCOE40 carb.
When the air filter is removed, fuel splashes/sprays out of the venturi. The backside of the filter was soaked.
Is it too simple to say the weber is delivering too rich of a mixture for proper combustion? Thoughts?
alfaronto is offline
post #2 of 17 (permalink) Old 06-16-2019, 06:24 PM
BB Janitor
ghnl's Avatar
Any chance the firing order is incorrect?
alfaronto likes this.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #3 of 17 (permalink) Old 06-16-2019, 07:19 PM
Push hard and live
DPeterson3's Avatar
I’d also check the float level in both carbs.
I had a freshly overhauled 40DCOM delivered with a tiny leak in its float. Over weeks it filled, leading to dramatic over-fueling of cylinders 3 and 4. As it happened so slowly, I didn’t catch it in time, and it washed all the lube off of those two cylinders, wiping out them and those two pistons.
You can do a quick level check by dropping a piece of clear 1/8” fuel line down into an emulsion well after running the electric pump long enough to fill the float chamber.
May we assume you are using a low-pressure fuel pump rather than the electric pump that served the Spica system?
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is online now
post #4 of 17 (permalink) Old 06-17-2019, 01:16 AM
check the rubber carb mounts too, they split
62 LANCIA FLAMINIA GT 2500 PROJECT (now sold) 64 SPRINT GT (Gone)
68 1750 ROUND TAIL SPIDER 70 1750 GTV 62 101 GIULIA SPRINT
ITALCAROZ is offline
post #5 of 17 (permalink) Old 06-17-2019, 07:16 AM Thread Starter
It possible though unlikely. I'll check tonight as this is an easy one to rule out.
post #6 of 17 (permalink) Old 06-17-2019, 07:25 AM Thread Starter
I'll also check that tonight. I've ditched the old box fuel pump in favor of a Carter unit. Will over pressuring of the carbs lead to the emulsion well overflowing?
post #7 of 17 (permalink) Old 06-17-2019, 08:10 AM
The fuel pressure should be 3 psi +/- 0.5. Flooding is dependent upon the pressure and the size of the needle valves. 2.75 should be big enough for a stock or moderately tuned 2L engine. Smaller needle valves are more tolerant of over pressure. But if only one carb is flooding then the float may be incorrectly adjusted or even punctured.
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is offline
post #8 of 17 (permalink) Old 06-17-2019, 09:06 AM
Push hard and live
DPeterson3's Avatar
As noted, there is a spec for float-type carburetors. They don't need much pressure to work correctly, primarily just needing adequate flow to feed the engine. Too much pressure will push the needle off the seat and overfill your carbs, resulting in a flow into the barrels that is quite a bit more than the engine wants.
The Weber-specified method of setting the float height requires removal of the top and manually measuring a certain clearance. A quicker, and possibly more reliable way, is to remove the round jet cover, screw out an emulsion stack, turn on the pump to fill the carbs, and measure the height of the fuel level down in the well. There's a neat trick using a clear lucite rod, but I generally just drop a piece of clear, small diameter fuel line into the hole, place my finger over the top, and pull out the resulting column of gas. You must draw a line on the fuel hose which you use to line up with the upper surface of the aluminum at the emulsion hole, and another line 25mm below the first. Insert the hose to the top line, cover with finger, and pull it out. The fuel level should be pretty close to the 25mm line.
Needless to say, if you remove an E-stack, turn on the pump, and fuel rises to the top, or near the top, of the e-stack hole, you've found your problem.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #9 of 17 (permalink) Old 06-18-2019, 02:28 PM Thread Starter
sadly the firing order is bang on
Gonna swing by the local Alfa guy here in TO and see if there is a quick diagnostic path.
post #10 of 17 (permalink) Old 06-18-2019, 04:27 PM
Ranz's Avatar
I had similar worries this week with my 1600 GTV with DCOE40s. No #4 cyl just didn’t seem to be pulling its weight, with no rev drop when plug wire pulled, tho car still pulled like a train.
Richening the idle screw for that cylinder restored a consistent rev drop.
(Now, my amateur brain is wondering if I am compensating for another problem altogether, but I can’t think what, as spark and compression were good)
What this says to me is that the differential in fuel delivery meant 3 cylinders were carrying the 4th. In your case, it’s two cyl carrying the other two. What’s left, if jets are clean and everything else seems ok, is carb balance, which I can’t see mentioned above. Maybe your rear carb is opening butterflies well before the front, and the rear carb is carrying the idle load. This may also explain the down on power thing.
There are a few tips here on the BB on checking consistent butterfly openings thru the progression holes, which is probably the most accurate way to do it...you just need good eyesight.
Ranz is offline
post #11 of 17 (permalink) Old 06-18-2019, 05:32 PM
What kind of fuel pressure regulator are you using and what pressure is it set to?
85 GTV6 3L
2011 Jaguar XKR
post #12 of 17 (permalink) Old 06-20-2019, 04:35 PM
I second this, I had a very very similar issue to you and turned out that my fuel pump was delivering too much fuel. AlfaParticle showed me the proper fuel pressure regulator to get and that ended up saving my tail.
Assuming the spark plugs are new and properly gapped, I also second checking the float level and maybe even cleaning the idle jets.
I feel like its safe to say the problem will be carb related since its the two cylinders served by the same carb, though I could be wrong (wouldn't be the first time).
When you say fuel comes out of the venturi's, is it dripping out or shooting? Leak or a sneeze ??
Aaron
Silver 1974 Spider, 2014 Honda Accord
AaronsSpider is offline
post #13 of 17 (permalink) Old 06-20-2019, 06:29 PM
Originally Posted by Ranz View Post
Whatís left, if jets are clean and everything else seems ok, is carb balance, which I canít see mentioned above. Maybe your rear carb is opening butterflies well before the front, and the rear carb is carrying the idle load. This may also explain the down on power thing.
I did the dance of the progression holes for a few years with two torches and then built myself a DIY manometer from two Aldi salad dressing bottles. Freakin amazing result.
TLDR: The accuracy and tolerances on that balance screw is far too fine using the progression holes, use a manometer.
Question: is the emulsion stack mentioned above just the great big long jet/tube things? Iím still working through a rough idle (have balanced the carbs, fitted 123Ignition... could be an air leak)
Craig_m67 is offline
post #14 of 17 (permalink) Old 06-21-2019, 09:19 AM
NMS
NMS's Avatar
Start with the simple things.
Fuel level, and carb sync.
BTW- in general, if you suspect air leaks: as the engine is idling, squirt carb cleaner at the suspected area. If the idle is affected, you located a/the problem.
NMS is offline
post #15 of 17 (permalink) Old 06-21-2019, 09:31 AM
Push hard and live
DPeterson3's Avatar
One can get the carb synch only so far off. If I understand the OP’s original post, he’s essentially lost the contribution of two cylinders. Even dramatically mis-synched carbs will make power once you get away from the lousy idle.
Most indicated sources of problem
Firing order swapped
Distributor cap failed (crack or carbon track)
Failed carb fuel supply or float level control.
Twin dead mice plugging intake tracts.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
