oil pump - Page 2 - Alfa Romeo Bulletin Board & Forums
 13Likes
post #16 of 85 (permalink) Old 06-17-2019, 10:56 AM
Gordon Raymond's Avatar
On some aftermarket pumps sent me, the relief valve upper body cylinder appears drilled with a wood auger! This DOES cause the piston to freeze in that cylinder as it might catch against a ridge or groove in the cylinder, causing high pressure.
As a rule with most Alfa parts that move or might cause whatever "system" failure, Brian's comment is 100% correct..."It sounds like the bottom line is, if it's going in the engine, don't pinch pennies."
Gordon Raymond
Now:
Last edited by Gordon Raymond; 06-17-2019 at 01:06 PM. Reason: Original **** word was a variation on tilt, beginning with letter c.
Gordon Raymond is offline
post #17 of 85 (permalink) Old 06-17-2019, 12:28 PM
It is more than a case of pinching pennies. It is often a case of installing a part that was designed without the knowledge of the original design specs and/or manufactured by a company that does not have an adequate quality assurance program. Failure of such parts is not uncommon.
alfaloco likes this.
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is offline
post #18 of 85 (permalink) Old 06-17-2019, 04:57 PM Thread Starter
gigem75's Avatar
I checked the play in the pump shaft on the other motor with the same pump and I pulled that motor just in time. A LOT of lash. Fortunately I had built "the one" with Alfaholics forged pistons, balanced crank, etc, windage tray, 30 deg big intake valves, RJ cams, MSD Streetfire ignition, 123 Bluetooth, Kent valve springs, and ported head where I went easy on the exhaust porting that was ready to go. BTW if anyone gets the Alfaholics forged pistons you will need to narrow the small end down to 21.99 mm so the small end will fit into the piston. A little tidbit they don't tell you on the website. But it's all good now and I'm very satisfied with the parts. Oh and a new oil pump from Classic Alfa. I also used their "race" timing chains and got the best fit ever on the lower one.
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #19 of 85 (permalink) Old 06-17-2019, 05:59 PM
Alfajay's Avatar
Originally Posted by 101/105guy View Post
And remember the original vendor recalled the pump because the relief valve retainer hole was in the wrong place! That certainly would cause the pressure to remain too high.
Oops, I had forgotten about that. OK, that explains the high oil pressure.
Originally Posted by gigem75
I thought Richard was talking about the drive gear on the crank. Since it can't be installed backwards on the crank (it can but I doubt it would even start)....
Right, that was my point about the gears not even touching if the one on the crankshaft is installed backward. Distributor won't turn, engine won't start, so no damage done.
.... or he was talking about the drive gear on the oil pump being installed backwards or upside down really by the manufacturer.
Got it. The gear on the oil pump may have been upside-down.
'63 Guilia spider
Alfajay is offline
post #20 of 85 (permalink) Old 06-18-2019, 06:47 AM Thread Starter
gigem75's Avatar
With the benefit of 20/20 hindsight I now know what the whirring sound is that I heard. At first I thought it was the spica belt cogs since it sounded like a fast bicycle with playing cards taped to the fender. I never could track it down and pretty much ignored it. Now I know it was the oil pump. I also compared the spring to a stock factory pump and it is about 7mm shorter and has fewer coils. It also feels stiffer but can't say how much. Bottom line is that if you hear something that sounds like cards on a bicycle and you just put a new oil pump in that was cheaper than average (under 200) stop!
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #21 of 85 (permalink) Old 06-18-2019, 07:30 AM
Richard Jemison
Alfar7's Avatar
Pump gears
I thought Richard was talking about the drive gear on the crank. Since it can't be installed backwards on the crank (it can but I doubt it would even start) he was either pulling my leg or he was talking about the drive gear on the oil pump being installed backwards or upside down really by the manufacturer.
I was not being facetious, your wear pattern would indicate either
mis- alignment of the gears, improper contact (small diameter of the oil pump gear) or softer alloy or material of the gear. As well the surface angle of gears must be the exact same so that there is a perfectly even contact pattern on both gears.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #22 of 85 (permalink) Old 06-18-2019, 07:50 AM Thread Starter
gigem75's Avatar
No sweat. It would be hard to have either gear in backwards is what I was referring to.
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #23 of 85 (permalink) Old 06-18-2019, 10:11 AM
[/QUOTE]
This is why they're called "pattern parts" I suppose. The difference is one of apparent quality versus actual quality.
180OUT is offline
post #24 of 85 (permalink) Old 06-18-2019, 10:16 AM
We seem destined to take backward steps on our way forwards. Maybe that is why we feel so good when we finally get it right.
85 GTV6 3L
2011 Jaguar XKR
post #25 of 85 (permalink) Old 06-18-2019, 06:10 PM
Gordon, source for the (good) pumps, or...you?
What caused such damage to the gear? I mean, I could not do that bad on a crownwheel without setting tools!
Regards, Alberto
aguirola is offline
post #26 of 85 (permalink) Old 06-18-2019, 07:11 PM
If the crown wheel was made of brass and the pinion of hard steel?
85 GTV6 3L
2011 Jaguar XKR
post #27 of 85 (permalink) Old 06-18-2019, 07:48 PM
...and no bearings...
Regards, Alberto
PS. I would still like to know what happened in technical terms
aguirola is offline
post #28 of 85 (permalink) Old 06-18-2019, 07:59 PM
We know of two that failed after a short time and both were installed by individuals who have built a few Alfa motors so things done by the manufacturer almost certainly caused the failure. Incorrect material of construction was a contributing factor. I wonder if these pumps were made on a special order from the vendor of the two failed ones or if they have a wider distribution.
85 GTV6 3L
2011 Jaguar XKR
post #29 of 85 (permalink) Old 06-19-2019, 07:53 AM
In this case, it is likely that excess outside axial clearance caused the failure. There are 2 axial clearances in these pumps, interrelated. Internally, gear top to upper body flange, and externally, upper body tower bush to bronze gear bottom. There is a build tolerance as mass production of ORIGINAL FACTORY pumps components varied a bit and that was designed into factory clearances. However, too much clearance here allows the bronze gear to move up-and-down against the hardened steel gear, resulting in the hourglass wear-THROUGH seen. I've had many other pumps with soft brass gears that show the beginnings of this wear pattern.
Ed. They have a wider distribution. Our vendors often do not know the quality of aftermarket parts unless failures are reported. They are NOT manufacturers, component testers or engineers. They are trying to fill a demand. This is complicated by good components, used in incorrect applications. A good 2L oil pump for a slower speed FI engine, used in a faster running 1600 with Webers, does not last long. This is an application mis-match, rather than "bad" pump.
All the above, my opinions from my own personal experiences.
Gordon Raymond
Now:
post #30 of 85 (permalink) Old 06-19-2019, 09:58 AM
What is different in the design of 1600 and 2L pumps that enables one to run faster than the other?
Catalogo Rapido Ricambi shows the same pump 105.14.06.013.01 for all 1300, 1600, 1750 and 2000 engines.
85 GTV6 3L
2011 Jaguar XKR
