pre 74 exhaust manifold in an S3 question. - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By capisce
post #1 of 3 (permalink) Old 06-10-2019, 06:54 PM Thread Starter
I have a 1987 Spider with stock exhaust ( Catalytic etc.)
The #4 pipe in the exhaust manifold has a crack.
I would like to swap the manifold for either a pre-74 or the one used in the 90's Spiders.
Questions:
1) Which one is the better of the two?
2) Will either or one of them FIT with no modifications to the rest of the exhaust. Should I expect any interference with other components.
I would appreciate some pointers.
Con Brio likes this.
capisce is offline
post #2 of 3 (permalink) Old 06-14-2019, 03:42 PM
Member
The earlier 2-piece exhaust manifold requires the matching front pipe section. It will NOT match up to your current system. Can't comment accurately on the S4 manifold.
Jon Harrison
'82 GTV6 - Death by Oldsmobile
'87 Milano Verde - Self Immolation
'86 Spider Quad - On the rebuild
Con Brio is offline
post #3 of 3 (permalink) Old 06-15-2019, 06:07 PM
genericwood's Avatar
We recently put an early type cast iron header in a S3. It requires the early downpipe, which you will need to modify to take the oxygen sensor.
Erik
'66 GTV racecar, '71 Spider racecar, '74 GTV street car, '71 GTV project
genericwood is offline
