86 spider vvt solenoid install - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 06-02-2019, 04:59 PM Thread Starter
I hate to post this as I know it must be already covered elsewhere but I can't find it. I just bought an 86 Spider and noticed the VVT solenoid was just free hanging by the wire harness. The mounting bracket is there but the rubber bushing is completely gone. I bought an insert from Ape that needs to be pressed into the mounting bracket so that I can install the solenoid. (the solenoid functions) My question is how to correctly install the solenoid? Specifically how to gauge or set it appropriately in relation to the pin it pushes in to advance the timing. The pin that extends out of the cam cover. I assume there is a specific depth to screw the solenoid into the mounting bracket. Thanks fellas.
Haba1492 is offline
post #2 of 4 (permalink) Old 06-02-2019, 05:50 PM
BB Janitor
ghnl's Avatar
I don't know the answer off hand but it must be here somewhere. Often a Google search finds results quicker. Just type in 'AlfaBB, <what you seek>' in the search box.
Also there is some info about setting up the VVT in the L-jet Spider page (link in my signature).
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #3 of 4 (permalink) Old 06-02-2019, 06:00 PM
Gubi's Avatar
TSB 00.90.08 has the instructions. Basically:
1) Screw the solenoid all the way in
2) Back it out until the plunger stops following the solenoid (looking through the little inspection hole) and there is clearance between the solenoid and follower
3) Screw the solenoid back in by hand until it just touches the plunger
4) Tighten the lock nut to 10 ft-lb
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #4 of 4 (permalink) Old 06-06-2019, 08:37 PM Thread Starter
Thanks Gubi. Kinda what I thought but wanted to make sure.
Haba1492 is offline
