105 Series 2L Spica - not idling, revs fine - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 05-12-2019, 08:29 AM Thread Starter
Freshly rebuilt motor with new starter
It turns over, fires and runs wall as long as the throttle is held to ~2500 rpm
When the revs are allowed to drop, it dies when trying to idle
It's not fueling or ignition issue as it revs freely and smoothly
Seems to be a Spica idle adjustment or vacuum hose issue perhaps
What are the easy fixes / trouble shoots?
Thank you
alfisti berlin is offline
post #2 of 3 (permalink) Old 05-12-2019, 05:54 PM
Thank you
I just pulled my 2L out of winter storage and had the problem. It turned out to be bad gas and poorly gapped plugs. Runs great now.
That said, I'd recommend going thru the SPICA setup step by step to make sure you're where you should be.
gprocket is offline
post #3 of 3 (permalink) Old 05-24-2019, 05:15 PM
r-mm's Avatar
You will find lots of SPICA step by step guides they are important to follow. I will add to this: check the maligned and overlooked o-ring in the air tower. The forum wisdom seems to be it does nothing but I solved my SPICA dying at idle problem with a plump fresh oring that let me control idle air and lean out mixture.
That said not idling below 2500 sounds like you are very lean or have lots of air leaking. Check throttle bodies, brake booster. What do the plugs look like ?
'73 GTV bare metal project... nearing 'car' status
E30 Daily - '65 912 project... no longer in waiting
r-mm is offline
Similar Threads
My suggestion to American Alfisti who want a manual Guilia PSk Giulia (2017-current) 45 06-17-2017 05:02 AM
Email from Reid Bigland regarding the lack of manual in the US James Locopo Giulia (2017-current) 34 11-07-2016 04:33 AM
Can anyone list the differences between a 105 Series 1 and a 105 Series 2 please. carbon8 Australian Forum 41 03-02-2016 05:21 AM
My 1750 Bella - Rebuilding a Series 2 105 1750 GT Veloce Coupe carbon8 GT (1963-1977) 46 01-09-2011 07:27 PM
Buying a spider Gene Cricco Spider - 105 & 115 Series (1966-1994) 27 04-08-2007 06:36 PM
