105 Camshafts gear removal - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 05-08-2019, 12:25 PM Thread Starter
Hi Alfistis,
Iím on the process of changing the camshafts of my 1973 gtv. Iím trying to remove the timing gears, but itís pretty locked. I donít want to damage the original camshafts, so does anybody has an idea how I can remove these gears?
Thank you
Best regards
Ludo
Aubryl is offline
post #2 of 6 (permalink) Old 05-09-2019, 06:18 AM
GTA R's Avatar
Originally Posted by Aubryl View Post
Hi Alfistis,
Thank you
Best regards
Ludo
Presumably you mean the gears on the forward end of the camshafts ?
If so, yes, just remove the end nut & washers and tap the gear off the end of the cam. (they are on a keyway).
If it doesn't come off easily, someone before you may have dmaged the key and / or keyway in some way.
GTA R
1963 Giulia Ti Super Rep
GTA R is offline
post #3 of 6 (permalink) Old 05-09-2019, 07:08 AM
Alfajay's Avatar
Remove the end nut & washers and the small nut & bolt that goes through one of the many pairs of holes between the cam and sprocket. Is it possible you neglected to remove that bolt?
'63 Guilia spider
Alfajay is online now
post #4 of 6 (permalink) Old 05-09-2019, 12:12 PM Thread Starter
Thank you GTA R and Alfajay,
My issue is the end nut seems ceased, and I don’t know how to lock the camshaft to avoid damaging it in the clamping device. Any idea how I should proceed?
Ludo
Aubryl is offline
post #5 of 6 (permalink) Old 05-10-2019, 05:27 AM Thread Starter
Update
I still haven't been able to remove the gears on my standard camshaft, but the good news is I don't need to anymore. I found a local mechanic I thought who could help me removing it, and had a pair of spare gears. So I got these and it means I can keep the std camshafts with the gears and correct timing in case I want the engine back to standard. Sometimes an issue leads to a better than expected solution
Best regards
Ludo
Aubryl is offline
post #6 of 6 (permalink) Old 05-20-2019, 05:45 PM
They are not gears, they are sprockets.
Chris
1967 Duetto Spider
alfabecker is offline
Tags
105, camshafts, gtv, nord, removal
Similar Threads
Wanted: 105 Front Spring Removal Tool alfa2go Alfa Romeo Parts For Sale & Wanted 5 07-24-2017 05:28 PM
Help diagnose strange 105 gear shifter getting stuck issue Nakagtv Gearbox, Transaxle, Differential & Propshaft 2 01-12-2014 01:16 PM
Inlet Manifold Removal - 105 coupe Ajhea Carburetors, Fuel Injection & Air Intake 2 10-03-2013 02:31 PM
Sequential Gearbox AndrewO GTA (1965-1975) 69 12-09-2009 02:10 AM
Removal of lower Timing Chain Gear Sprintn Engine Repair, Diagnostics & Rebuilding 10 09-29-2007 12:38 PM
