Nord Head Plugs - Nut/Bolt Size to get it off - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 04-18-2019, 02:59 PM Thread Starter
AlessandroM's Avatar
Hey there
I would like to remove a head-plug from my car to install another coolant temp sensor - has anyone done this recently and found a fitting nut or bolt? All the metric ones that I have are either too small or too big, and would harm the plug.
Thanks a lot
Alessandro
Learning, learning..
AlessandroM is offline
post #2 of 8 (permalink) Old 04-18-2019, 03:25 PM
Drill, die grinder, pick threads clean.
guillotineFI is offline
post #3 of 8 (permalink) Old 04-18-2019, 11:38 PM Thread Starter
@guillotineFI
That will be hard since the engine is installed and running. Other seems to be able to remove it just fine, but I haven't found anyone actually mentioning the size (bolt or nut) they used.
post #4 of 8 (permalink) Old 04-19-2019, 01:40 AM
quadrifolio's Avatar
if memory serves well its a 14mm allen key and the treads are m22x150
quadrifolio is offline
post #5 of 8 (permalink) Old 04-19-2019, 11:35 AM
Originally Posted by AlessandroM View Post
@guillotineFI
Understood. But, my experience is that the aluminum plug hex socket, is likely no match to the combination of tool steel hex wrench and factory applied "galvanic corrosion" brand of time curing thread locker.
Just be aware, and consider going easy on it before ruining the socket and having little choice between going with the proven approach, or living with an ugly plug.
post #6 of 8 (permalink) Old 04-19-2019, 09:57 PM
On removing the head plug would it be easier to do after the engine has been running and the alloy is hottish ? Just thinking the corrosive seal may loosen more easily with the heat.
Tim
exhausted is offline
post #7 of 8 (permalink) Old 04-21-2019, 10:09 AM
Hey Alessandro
You said
" ...I would like to remove a head-plug from my car to install another coolant temp sensor..."
Well that's interesting. Are you planning to install the sender in the hole left by the departed plug, which according to another poster is M22x1.50?
Problem is that the plug threads tend to shear off and remain in the internal threads cut into the head. This isn't so bad as you can remove the plug fragments from the internal threads using an O-ring pick as GuillotineFI suggests.
Much worse is when the plug threads shear off the internal threads cut into the head. Now this is bad. You'll have to acquire a 22mm Timesert kit, drill out the hole and install the insert. I doubt you can do this successfully with the cylinder head in the car.
My point in all this is that when you put the Allen key into the plug and start to twist, you're starting down the road that will likely lead with cylinder head replacement. Definitely use a T-handle Allen key to avoid side loading the Allen plug.
Keep us informed on how this goes.
Bye
Milanoguy is offline
post #8 of 8 (permalink) Old 04-21-2019, 05:32 PM
I was wanting to do the same thing to add another (mechanical) temp gauge. I thought another option may be to add a "T" connector into a heater hose. Or maybe there is an easier way to get a 1/4" pipe threaded fitting into ??
930cabman is offline
Tags
head plug
Similar Threads
Wanted: Cylinder Head Plugs (front) Delllta Alfa Romeo Parts For Sale & Wanted 2 12-16-2012 09:17 AM
Crank bolt and head plugs Jimmler Spider - 105 & 115 Series (1966-1994) 9 07-23-2012 05:06 PM
GTV6 head doesn't want to part with block salamandrrr Alfetta & GTV6 (1972-1986) 10 04-10-2008 04:35 PM
Biggets possible inlet valve in Nord 1600 head? rogga2 Engine Repair, Diagnostics & Rebuilding 5 02-28-2008 11:23 PM
anyone have a nord head for sale in SoCal area? davbert Alfa Romeo Cars For Sale & Wanted 0 09-19-2006 02:29 AM
