Oil pressure sending unit removal - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By ghnl
  • 1 Post By Gubi
post #1 of 13 (permalink) Old 03-04-2019, 02:04 PM Thread Starter
VabeneGTV's Avatar
Help, I have a 78 Alfetta sedan, Euro spec, trying to remove the existing oil pressure sending unit, found out its a 14 mm hex nut, have the 14 mm thin wrench, which is on the shorter side. I can't seem to get enough leverage to start the unit spinning. I have tried the interlocking wrench trick, still a nogo. I suspect it's the original and perhaps never removed. Any thoughts? TIA
Cars ruined my life! 😱
VabeneGTV is online now
post #2 of 13 (permalink) Old 03-04-2019, 03:49 PM
BB Janitor
ghnl's Avatar
Twist harder - counter clockwise. If you are sure the wrench is fitting onto the hex behind the sender (I've seen them with 14mm & 17mm hex) once you get it to move about 1/4 turn it'll probably come out easily. Even with a so-called thin wrench I wasn't always able to get fully on the hex. I got a bicycle wrench - stamped out of 1/8" thick steel & easily bent or cut to a custom size.
divotandtralee likes this.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #3 of 13 (permalink) Old 03-04-2019, 04:09 PM
Del
Or, a thinned crow's foot socket.
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is offline
post #4 of 13 (permalink) Old 03-05-2019, 04:05 PM Thread Starter
VabeneGTV's Avatar
Thanks for the ideas, as mentioned it is 14mm, the thin wrench fits suggly on it. I have twisted harder to no avail. I tried a strap wrench, no luck. Love the thin 14mm crow foot idea, I have no problem grinding one down to make it thinner, the problem I forsee is that most of the crow foot wrenchs I've seen have the drive opening for the ratchet rather close to the open end and I doubt the opening will clear the back of the sensor, precluding it's use.
I was able to get vice grips on the sender and have movement, however I think what is happening now is that the sender body is now spinning in the crimped backing that the hex nut attaches to, and the 14mm nut still doesn't turn, so still Working it. Argghhhh
post #5 of 13 (permalink) Old 03-05-2019, 04:19 PM
Gubi's Avatar
Yep.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #6 of 13 (permalink) Old 03-05-2019, 05:36 PM
+1 or maybe -1. I have tried the strap wrench method and failed miserably.
Ruin a functioning sender!!
930cabman is online now
post #7 of 13 (permalink) Old 03-06-2019, 12:47 AM
spiderserie4's Avatar
original factory wrench looked like this (poor photo, don't have another!)....the simple design allows a grip and gives leverage.
once you have broken the seal, the thing just spins off (well, yours spins already it seems)
spiderserie4 is online now
post #8 of 13 (permalink) Old 03-23-2019, 03:40 PM Thread Starter
VabeneGTV's Avatar
Finally beat that mother. I had ordered a 14mm from a place called Bentwrench, which has an offset to allow it to slip behind the sending unit, only after I ground it down to a thinner size, slid right in, but still couldn't budge it. Finally went back to the vice grips, clamped them over the part that folds over the backing plate since the body had been spinning on the backing plate. A little leverage with 17mm wrench finally broke it free, new one installed, didn't know what the next step was going to be, but luckily never had to go that route. Can I get an Amen!
post #9 of 13 (permalink) Old 03-23-2019, 04:34 PM
Gubi's Avatar
Well done.
Yeah, it's tough to get enough torque with a short wrench. I get a stubby wrench on the nut and then use a 3/8" socket extension and a hammer to whack on it. That usually gets it turning.
giulia_veloce likes this.
1974 GTV
1991 Spider
Gubi is online now
post #10 of 13 (permalink) Old 03-23-2019, 04:38 PM
BB Janitor
ghnl's Avatar
Yay! Did you try any Italian swear words? You must include the appropriate wrist action, eh!
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
post #11 of 13 (permalink) Old 03-24-2019, 04:41 AM
divotandtralee's Avatar
Finally beat that mother. , didn't know what the next step was going to be, but luckily never had to go that route. Can I get an Amen!
Congratulations ... not on getting the sender out .. but resisting to put the car on Craigslist. I'm sure it crossed your mind.
divotandtralee is offline
post #12 of 13 (permalink) Old 03-24-2019, 04:45 AM Thread Starter
VabeneGTV's Avatar
Many options went through my mind, however that was not one of them. I was in full McIver mode. Hope all is well!
post #13 of 13 (permalink) Old 03-24-2019, 05:00 AM
It will be well when we get to a last frost date as you know!!! Might be sometime in June!!! Opening Day .. April 9 ..Sox 2 tickets on 3rd base .. All is well!
Similar Threads
oil pressure sending unit adrianvee GT (1963-1977) 3 05-23-2012 01:28 AM
Oil sending unit. Is there a test in situ? peterlund Spider - 105 & 115 Series (1966-1994) 15 06-15-2009 02:10 PM
Wanted: Oil pressure sending unit RAGs Alfa Romeo Parts For Sale & Wanted 1 03-20-2009 01:11 PM
