1983 Spider - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 02-20-2019, 01:37 PM Thread Starter
1983 Spider
I am restoring my Spider from the ground up. Question.... Can I use a 1968 dash on an 1983 Spider? I just love the older dash.
Pjfranks303 is offline
post #2 of 8 (permalink) Old 02-20-2019, 02:40 PM
sprintgtc's Avatar
Sure, early "series 2" Spider Juniors had the metal Duetto dash, so it is possible. However, I believe the radius along the bottom of the windshield is different, so you'll most likely need to source a dashtop made for one of those Juniors. The rest of the dash could come from any roundtail from '66 to '70. Also, you'll have to decide if you want to use the later speedo & tach, or retrofit the car to use the earlier style cables.
Mike Macaulay
Seattle
69 Spider
69 GTV
74 GTV
84 Spider Veloce
18 4C Spider
sprintgtc is offline
post #3 of 8 (permalink) Old 02-20-2019, 06:03 PM Thread Starter
Thank you. What are your thoughts, should I do it?
post #4 of 8 (permalink) Old 02-21-2019, 07:58 AM
sprintgtc's Avatar
Personally, I like the early dash too and I think it would be a cool custom touch. Also, you will pick up some extra interior space. A quick search of Classic Alfa's website turned up this:
https://classicalfa.com/products.php...AND-DRIVE-ONLY
So there you go. The top is half the battle, and the rest of the Duetto style dash parts are pretty easy to find. Post some pictures!
Mike Macaulay
Seattle
69 Spider
69 GTV
74 GTV
84 Spider Veloce
18 4C Spider
post #5 of 8 (permalink) Old 02-21-2019, 08:20 AM
Andrew's Avatar
Yeah, 66-69 windshield is more upright than 1970 and later, probably a flatter curve at the base. I'd think the attachment differs, since Duetto dashes are metal and all later are rubber/foam with a frame.
Andrew
Andrew is offline
post #6 of 8 (permalink) Old 02-21-2019, 08:29 AM Thread Starter
Might be a huge undertaking. Thoughts on if I should do it? Links to any Duetto dash parts would be nice. I want to see how much this is going to cost me.
post #7 of 8 (permalink) Old 02-21-2019, 10:06 AM
lawrencedesigns's Avatar
So technically it would be a "remodel" instead of a "restoration."
Hell yes! Do it!!!
Keeth Lawrence
1988 Spider Veloce
lawrencedesigns is offline
post #8 of 8 (permalink) Old 02-21-2019, 11:30 AM Thread Starter
I am seriously thinking about it. Any links to source everything needed would be great. Thanks in advance.
Similar Threads
Available Wiring Diagrams papajam Electrical, Chassis & Lighting 1722 06-01-2019 05:35 AM
Alfa Performance Center. Com~~~~Parts AlfaLadyEastGTV Alfa Romeo Parts For Sale & Wanted 6 11-23-2015 06:20 PM
Nord engine alfanaut GT (1963-1977) 17 11-14-2009 10:11 AM
FS 1991 Automatic Spider & 1983 Veloce & 1991 164 BrewThack Alfa Romeo Cars For Sale & Wanted 8 09-07-2007 07:26 AM
Spider Concours Class Question Favali Alfa Romeo Topics Not Covered Elsewhere 10 08-26-2007 09:55 PM
