Restricted gas pedal movement on 1988 Spider - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 08-14-2017, 07:57 AM Thread Starter
Throttle pedal doesn't function smoothly, but it works fine from the throttle linkage under the hood.
Guessing I need to replace throttle grommets on firewall (one on each side), do you guys agree? If so, what's the best way to replace them?
Many thanks
Mario
ocalfa is offline
post #2 of 6 (permalink) Old 08-14-2017, 09:19 AM
BB Janitor
ghnl's Avatar
I had a binding throttle pedal in our '84 Spider (same throttle linkage as your '88). Turns out it was the bell crank under the intake plenum.
The photo was taken by holding my camera down near the distributor looking back under the intake plenum.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #3 of 6 (permalink) Old 08-14-2017, 09:26 AM
BB Janitor
ghnl's Avatar
Here's a picture (swiped from the BB) showing the underside of the plenum & how the bell crank is attached.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
post #4 of 6 (permalink) Old 08-14-2017, 10:37 AM Thread Starter
Thanks Eric. I don't have any problems when I pull up the throttle linkage under the plenum. Was Your experience the same?
The grommet seems out of shape/place and has tiny cracks! Any ideas of how to replace them?
ocalfa is offline
post #5 of 6 (permalink) Old 08-14-2017, 12:08 PM
BB Janitor
ghnl's Avatar
Anything here help? http://www.alfabb.com/bb/forums/spid...g-removal.html
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
post #6 of 6 (permalink) Old 08-14-2017, 01:48 PM
Norcal's Avatar
First, make sure carpet isn't getting in way. That causes problems. 2nd spray triflow on the rubber grommets on firewall before you replace them. They bind and get a little sticky. Get in there good. 3rd lube the little plastic connectors that the throttle rods connect to all the way up to the throttle body on intake. 3rd lube with triflow the spring under the plenum, and the spring that opposes throttle linkage. Finally, if little plastic connectors are broken, buy the newer metal replacement ends from Centerline or other vendors. Lubing and moving carpet solved all of my problems.
1987 S3 Spider Quad 81k miles- California car- no rust - always garaged - everything works!, until it doesn't.......
Norcal is offline
