Ignition timing - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By r-mm
post #1 of 5 (permalink) Old 04-01-2017, 09:36 AM Thread Starter
eas
eas's Avatar
Ignition timing
Hello follow Alfisti,
I am trying to adjust the Ignition timing as i just installed an electronic ignition, but I cannot see any marks on the pulley, neither on the engine block.
Are the marks on the alternator side or on the distributor side ?
From the Alternator side, vision is very restricted and I do not see how you can point a timing gun on to the pulley as there is the alternator and belt in the way, and on the distributor side, i am not see any marks !
Also, between the pulley and fan shroud, there isn't space to put a wrench to turn the engine, how can it be done ?
Car is a Euro GTV 2L 1971 on carbs
1971 - 2000 GT Veloce Euro
eas is offline
post #2 of 5 (permalink) Old 04-01-2017, 05:28 PM
Ranz's Avatar
The pulley marks are very feint. You probably need to look at the pulley from underneath to find them and mark them with liquid paper or similar.
The pulley needs to be very clean to see the marks - use some emery paper or steel wool to lightly polish the edges, and they should show up. A good light will help.
If you're having trouble turning the engine, you can put it in gear and rock/push the car forward to rotate the engine a quarter turn or so at a time, to both clean and locate marks. It doesn't take much. Plugs out will also help. In fact that might be enough to let you turn the engine using the fan belt. Painful process, but you should only have to do it the once to find and paint the marks.
The pointer is on the alternator side. It looks like a metal triangle with a tip pointing forwards to the pulley edge. It is attached to the water pump at about the 4 o'clock position, looking from the front. Yes, it is very hard to see from the top, especially if everything is dirty. You have to get the viewing angle just right, but you can see it.
Once everything is clean, and your marks are highlighted, you should be OK.
Good luck.
Ranz is offline
post #3 of 5 (permalink) Old 04-04-2017, 07:50 AM
Andrew's Avatar
You can get close by finding TDC on 1 or 4, look down the plug hole or put some kind of pointer in, bring the crank around til the pointer is at apogee. The P mark on the pulley should be pretty close to the timing pointer.
Andrew
Andrew is offline
post #4 of 5 (permalink) Old 04-05-2017, 06:36 AM
r-mm's Avatar
Ive found putting the car in gear and rotating one wheel the easiest way to handle this. Setting timing on the Alfa really makes me miss the Porsche...
DaVinci likes this.
'73 GTV bare metal project... nearing 'car' status
E30 Daily - '65 912 project... no longer in waiting
r-mm is offline
post #5 of 5 (permalink) Old 04-05-2017, 07:14 AM Thread Starter
eas
eas's Avatar
The engine isn't at all clean. Most probably it has layers upon layers of the black oily stuff since 1971.
I will remove the radiator and fan/shroud to have better access for some de-greaser cleaning and finally timing it by the book.
In the mean time I have rotated the distributor roughly to how it was before using pics I took before disassembly. In my opinion, timing came a little advance as the car is pulling like a train now (no signs of knock/pre-ignition pinging). Not sure if its related to the new revamp of all the ignition system , 98 Octane fuel or the advance timing, or all together. The car idles at 950 ish rpm.
eas is offline
