engine compression? - Page 3 - Alfa Romeo Bulletin Board & Forums
post #31 of 35 (permalink) Old 02-23-2015, 10:08 PM
You can check for air leaks by spraying starter fluid around the mounts. Some use propane gas. If the motor speeds up you likely have a leak.
gprocket is offline
post #32 of 35 (permalink) Old 02-23-2015, 10:23 PM Thread Starter
JimPunkrockford's Avatar
ahh that's what i was looking for. thanks i will give that a try.
JimPunkrockford is offline
post #33 of 35 (permalink) Old 02-25-2015, 11:48 AM Thread Starter
okay, this may be something. here is a video of the test. it is hard to tell because of such funky idling but maybe....
post #34 of 35 (permalink) Old 07-29-2019, 11:47 AM
The theory of introducing some flammable gas into the intake manifold works. We recently did exactly that and appeared to find the culprit with the soft mounts. New soft mounts and $120.00 later the loping idle and lack of a decent reading with our vacuum gauge leads me to believe the starting fluid test did not perform as intended. Not sure where to go from here, has anyone had luck with the "smoke test" for vacuum leaks in the intake system?
Yes, we are off topic
930cabman is offline
post #35 of 35 (permalink) Old 07-30-2019, 10:16 AM
slowcreek's Avatar
The problem with starting fluid is that it mostly evaporates before reaching the suspected vacuum leak source. I use brake cleaner or carb cleaner. You can use water if you like. You'll know when it hits the leak......
It's Giuseppe's giubos, not Guido's guibos, on my 78 Spider and Sport Sedan
slowcreek is offline
