valve clearance adjustment - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 05-07-2014, 07:01 PM Thread Starter
alfaromero1067's Avatar
Hello, looking for instructions on how to adjust valves on an 89 spider....If you could forward page from shop manual...appreciate your help..
alfaromero1067 is offline
post #2 of 5 (permalink) Old 05-08-2014, 05:35 AM
BB Janitor
ghnl's Avatar
Contact the Tech Librarian of the AROC-USA. Hey can help you get manuals for your car.
The short version is you have to remove the camshafts to access the shims underneath the buckets (aka tappets/cam followers). Swap in a thinner shim to increase the clearance or a thicker shim to decrease the clearance. There is a 'trick' where one can slacken the timing chain then carefully lift off one camshaft at a time without disconnecting it's gear from the chain to avoid having to split the chain.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #3 of 5 (permalink) Old 05-08-2014, 07:19 PM Thread Starter
Thanks Eric, I adjusted valves on Triumph years ago with just a feeler guage and a wrench..do I need to purchase these shims in different sizes?
post #4 of 5 (permalink) Old 05-08-2014, 09:29 PM
Push hard and live
DPeterson3's Avatar
Yes. You either need a friend who has a full stock of the shims and will swap out with you, or you will buy them one at a time which will be slow and expensive, or you will buy a full stock of shims which is a couple hundred dollars or so.
The shims come in steps of roughly .001. If you get anal about it, you can slightly grind the face, so long as you have the right tools for the job, and get all clearances spot on. Mostly, the stock shims will get you within an acceptable match of each other.
Once you've done the job a few times, it takes perhaps an hour to do an engine. The first time will probably take you a day.
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is online now
post #5 of 5 (permalink) Old 05-09-2014, 05:58 AM
BB Janitor
ghnl's Avatar
Sometimes, if you are really lucky, you can swap shims around - take one out of a tight valve and swap it for one with a loose valve. If so, you should also run right out and buy yourself a lottery ticket because it is your lucky day...
If you don't have that friend with a full set of shims you should at least measure & record every shim - even those that are 'in spec'. Then if at some future date you need to 'adjust' a valve you will know what thickness shim is in place & can calculate what new size you need (assuming you remember where you kept the list you made).
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
